Shop the Holiday Gift Guide
Xbox 360 Jammed CD Belt Replacement
Views: 1.3K
View statistics:
Past 24 Hours:
2
Past 7 Days:
10
Past 30 Days:
23
All Time:
1,254
Comments: 1
1 guide comment.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 11
11 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Introduction
Go to step 1 ↓
This instruction manual will teach the user how to replace the CD Tray Belt. At the end the of this guide, the user should be able to replace the belt and reassemble the console. It is strongly recommended that you have some knowledge of the console, and perform the replacement in a well lit area.
Parts
Tools
    1. Xbox 360 Jammed CD Belt  Replacement, Jammed CD Belt: step 1, image 1 of 1
      Tool used on this step:
      Buy
      • Remove the white plastic casing covering the Xbox.
      • Place the Xbox with the front part of the console facing you. Use the flat surface of the tweezers to prop the top part of the casing to remove the front casing of the console.
      Ask FixBot
    2. Xbox 360 Jammed CD Belt  Replacement: step 2, image 1 of 3 Xbox 360 Jammed CD Belt  Replacement: step 2, image 2 of 3 Xbox 360 Jammed CD Belt  Replacement: step 2, image 3 of 3
      • Stand the Xbox up so the bottom part is facing up. Use your nail and poke at the second hole on the second row on the side of the Xbox.
      • The next hole is the twenty-first hole on the third row.
      • The final hole is the second to last hole on the fourth row. Repeat on each side, top and bottom.
      Ask FixBot
    3. Xbox 360 Jammed CD Belt  Replacement: step 3, image 1 of 3 Xbox 360 Jammed CD Belt  Replacement: step 3, image 2 of 3 Xbox 360 Jammed CD Belt  Replacement: step 3, image 3 of 3
      • Remove grey plastic piece and place the console with the front facing you.
      • You will see four clips. Take a multi-screwdriver and use the flat screw or a plastic spudger to unhook the clips.
      • Once unhooked, flip Xbox so the bottom of the console is facing you.
      Ask FixBot
    4. Xbox 360 Jammed CD Belt  Replacement: step 4, image 1 of 2 Xbox 360 Jammed CD Belt  Replacement: step 4, image 2 of 2
      • Take the tweezers, or pliers, and poke the seven holes that are visible to you. Remove the cover.
      Ask FixBot
    5. Xbox 360 Jammed CD Belt  Replacement: step 5, image 1 of 2 Xbox 360 Jammed CD Belt  Replacement: step 5, image 2 of 2
      • Place the console with the metal side facing you and take your multi-screwdriver (using the star head) and remove the six screws labeled in the picture below
      Ask FixBot
    6. Xbox 360 Jammed CD Belt  Replacement: step 6, image 1 of 1
      • Remove the other half of the white casing.
      Ask FixBot
    7. Xbox 360 Jammed CD Belt  Replacement: step 7, image 1 of 3 Xbox 360 Jammed CD Belt  Replacement: step 7, image 2 of 3 Xbox 360 Jammed CD Belt  Replacement: step 7, image 3 of 3
      • Flip the console with the hardware facing up. There will be a grey box that is connected to the console, with white and black wires exposed.
      • Disconnect both wires and remove half of the piece of silver electrical tape, careful to not remove the entire tape.
      Ask FixBot
    8. Xbox 360 Jammed CD Belt  Replacement: step 8, image 1 of 1
      • Place the box so the bottom is facing up. Remove the four screws labeled in the picture below with a multi-screwdriver with the five-point head.
      Ask FixBot
    9. Xbox 360 Jammed CD Belt  Replacement: step 9, image 1 of 3 Xbox 360 Jammed CD Belt  Replacement: step 9, image 2 of 3 Xbox 360 Jammed CD Belt  Replacement: step 9, image 3 of 3
      • Place pressure on black rods to remove the top casing of the drive.
      • Place the drive facing you. This should expose a small hole.
      • Take the nail and gently unwind the gear inside the hole. When finished, the tray should be out.
      Ask FixBot
    10. Xbox 360 Jammed CD Belt  Replacement: step 10, image 1 of 2 Xbox 360 Jammed CD Belt  Replacement: step 10, image 2 of 2
      • Use your tweezers to remove the band.
      Ask FixBot
    11. Xbox 360 Jammed CD Belt  Replacement: step 11, image 1 of 1
      • Replace old band with new.
      • To reassemble, complete these steps in reverse order.
      • You may hear clicking sounds when re-attaching the pieces held together by clips. This is normal, and expected.
      Ask FixBot
2 other people completed this guide.
Author
with
joey
242 Reputation
1 Guide authored
1 Guide Comment
Lol. Avoid drugs & alchohol or you could potentially make an err. Wow. Like the guide though! Thx.
Chris Fisher - Reply Share
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 23
All Time: 1,254
