Xbox 360 E Wi-Fi Card Replacement
  1. Xbox 360 E Wi-Fi Card Replacement, Top Panel: step 1, image 1 of 1
    Tool used on this step:
    Spudger
    $2.99
    Buy
    • Push the Spudger into the crevice between the grated top panel of the Xbox and the bottom body with the rubber feet.
    • Pull back on the spudger like a lever, keeping it pressed firmly into the crevice.
  2. Xbox 360 E Wi-Fi Card Replacement: step 2, image 1 of 1
    • Slide the spudger along the separation you have created between the grated panel and the bottom body of the Xbox.
    • Periodically pull back on the spudger like a lever, keeping it pressed firmly into the crevice.
  3. Xbox 360 E Wi-Fi Card Replacement: step 3, image 1 of 3 Xbox 360 E Wi-Fi Card Replacement: step 3, image 2 of 3 Xbox 360 E Wi-Fi Card Replacement: step 3, image 3 of 3
    • Continue sliding the spudger along the perimeter of the left grated face of the Xbox.
    • Pull the top panel off.
  4. Xbox 360 E Wi-Fi Card Replacement, Wi-Fi Card: step 4, image 1 of 1
    • Remove the 11 mm screw left of the green wifi-card using the T9 Torx screw bit.
  5. Xbox 360 E Wi-Fi Card Replacement: step 5, image 1 of 2 Xbox 360 E Wi-Fi Card Replacement: step 5, image 2 of 2
    • Firmly grip the green Wi-Fi card and pull it out of the Xbox.
Jennifer
1,909 Reputation
4 Guides authored
Cal Poly, Team 2-11, Amido Winter 2014 Member of Cal Poly, Team 2-11, Amido Winter 2014
CPSU-AMIDO-W14S2G11
4 Members
43 Guides authored
Past 24 Hours: 3
Past 7 Days: 27
Past 30 Days: 101
All Time: 10,152
