Toshiba Satellite 1805-S177 Screen Replacement
Views: 4K
View statistics:
Past 24 Hours:
2
Past 7 Days:
32
Past 30 Days:
115
All Time:
3,980
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 - 40 minutes
Difficulty: Difficult
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Inconsistent Images
Updating the images on this guide to be more consistent with the prerequisites would increase its awesomeness.
Introduction
Go to step 1 ↓
Usually, when the screen no longer works, the area behind the screen is also damaged. This guide shows you how to replace the screen of your Toshiba Satellite 1805-S177 laptop.
Tools
    1. Toshiba Satellite 1805-S177 Screen Replacement, Battery: step 1, image 1 of 1
      • Placing your finger on the raised grip, push the battery casing to the right. It will slide over.
      Ask FixBot
    2. Toshiba Satellite 1805-S177 Screen Replacement: step 2, image 1 of 1
      • Pull the battery casing gently out toward yourself, until you hear a clicking sound.
      • The battery should pull out to about 2 inches.
      Ask FixBot
    3. Toshiba Satellite 1805-S177 Screen Replacement: step 3, image 1 of 1
      • Lift the battery casing out of the laptop.
      Ask FixBot
    1. Toshiba Satellite 1805-S177 Screen Replacement, Hard Drive: step 4, image 1 of 2 Toshiba Satellite 1805-S177 Screen Replacement, Hard Drive: step 4, image 2 of 2
      • Look at the bottom of the laptop. Using a Phillips screwdriver, unscrew and remove the screw labeled F4, located on the cover of the hard drive.
      • The hard drive is located next to the CD drive.
      Ask FixBot
    2. Toshiba Satellite 1805-S177 Screen Replacement: step 5, image 1 of 1
      • Placing your finger on the raised grip, push up on the hard drive cover. This will remove the hard drive cover from the laptop.
      Ask FixBot
    3. Toshiba Satellite 1805-S177 Screen Replacement: step 6, image 1 of 2 Toshiba Satellite 1805-S177 Screen Replacement: step 6, image 2 of 2
      • Using a Phillips screwdriver, unscrew and remove the screw surrounded by the white plastic.
      Ask FixBot
    4. Toshiba Satellite 1805-S177 Screen Replacement: step 7, image 1 of 1
      • Pull the white plastic out toward you. This should remove the hard drive tray from the laptop.
      • This laptop does not have a hard drive, so the tray is empty. On your computer, the hard drive should be in the tray.
      Ask FixBot
    1. Toshiba Satellite 1805-S177 Screen Replacement, Keyboard: step 8, image 1 of 2 Toshiba Satellite 1805-S177 Screen Replacement, Keyboard: step 8, image 2 of 2
      • Stick a spudger in one of the sides of the top panel. Lift slowly from one side to the other and it will pop off.
      Ask FixBot
    2. Toshiba Satellite 1805-S177 Screen Replacement: step 9, image 1 of 3 Toshiba Satellite 1805-S177 Screen Replacement: step 9, image 2 of 3 Toshiba Satellite 1805-S177 Screen Replacement: step 9, image 3 of 3
      • Using an Phillips screwdriver, unscrew and remove two screws labeled B2.6.
      Ask FixBot
    3. Toshiba Satellite 1805-S177 Screen Replacement: step 10, image 1 of 1
      • Using your hands, lift keyboard up toward you, starting from the edge closest to the screen.
      • The keyboard is still connected to the laptop by a ribbon. Place the keyboard gently on top of the trackpad, keys side down.
      Ask FixBot
    4. Toshiba Satellite 1805-S177 Screen Replacement: step 11, image 1 of 2 Toshiba Satellite 1805-S177 Screen Replacement: step 11, image 2 of 2
      • Find the white ribbon connector (where the keyboard is still attached to the rest of the laptop).
      • Slide the white ribbon connector up and lift the ribbon out of it.
      Ask FixBot
    1. Toshiba Satellite 1805-S177 Screen Replacement, TrackPad: step 12, image 1 of 1
      • Using a Phillips Screwdriver, unscrew and remove the one F4 screw closest to the center of the laptop.
      • This screw is underneath the battery casing, located on the bottom of the laptop directly under the trackpad.
      Ask FixBot
    2. Toshiba Satellite 1805-S177 Screen Replacement: step 13, image 1 of 1
      • Using your finger, lift off the plastic covering the trackpad by putting your finger underneath the plastic and pulling towards you. The plastic should just pop off.
      Ask FixBot
    3. Toshiba Satellite 1805-S177 Screen Replacement: step 14, image 1 of 2 Toshiba Satellite 1805-S177 Screen Replacement: step 14, image 2 of 2
      • Remove the left, brown ribbon by pinching the part of the ribbon connected to the computer and lifting towards you.
      Ask FixBot
    4. Toshiba Satellite 1805-S177 Screen Replacement: step 15, image 1 of 2 Toshiba Satellite 1805-S177 Screen Replacement: step 15, image 2 of 2
      • Remove the white ribbon on the right by pinching the part connected to the laptop with your fingers and pulling towards you.
      Ask FixBot
    5. Toshiba Satellite 1805-S177 Screen Replacement: step 16, image 1 of 1
      • Lift the track pad gently towards you, using your fingers.
      Ask FixBot
    1. Toshiba Satellite 1805-S177 Screen Replacement, Screen: step 17, image 1 of 2 Toshiba Satellite 1805-S177 Screen Replacement, Screen: step 17, image 2 of 2
      • Using a Phillips screwdriver, unscrew and remove 5 screws labeled F6, located on the metal piece on the left side of the keyboard area.
      Ask FixBot
    2. Toshiba Satellite 1805-S177 Screen Replacement: step 18, image 1 of 1
      • Using your fingers, pinch and lift metal piece away from the laptop and set aside.
      Ask FixBot
    3. Toshiba Satellite 1805-S177 Screen Replacement: step 19, image 1 of 2 Toshiba Satellite 1805-S177 Screen Replacement: step 19, image 2 of 2
      • Using a Phillips screwdriver, unscrew and remove two screws labeled B25 located closest to the screen.
      Ask FixBot
    4. Toshiba Satellite 1805-S177 Screen Replacement: step 20, image 1 of 3 Toshiba Satellite 1805-S177 Screen Replacement: step 20, image 2 of 3 Toshiba Satellite 1805-S177 Screen Replacement: step 20, image 3 of 3
      • Using a Phillips screwdriver, unscrew and remove two screws labeled B5.5, located to the right of where the metal piece was.
      • These screws are silver, where all the other screws have been black.
      Ask FixBot
    5. Toshiba Satellite 1805-S177 Screen Replacement: step 21, image 1 of 3 Toshiba Satellite 1805-S177 Screen Replacement: step 21, image 2 of 3 Toshiba Satellite 1805-S177 Screen Replacement: step 21, image 3 of 3
      • Using a Phillips screwdriver, unscrew and remove two black screws from the back side of the laptop.
      • These screws are not labeled.
      Ask FixBot
    6. Toshiba Satellite 1805-S177 Screen Replacement: step 22, image 1 of 1
      • Using a Phillips screwdriver, unscrew and remove F4 screw from plastic covering on the bottom of the laptop that only has one screw.
      Ask FixBot
    7. Toshiba Satellite 1805-S177 Screen Replacement: step 23, image 1 of 2 Toshiba Satellite 1805-S177 Screen Replacement: step 23, image 2 of 2
      • Using fingers,pinch and lift plastic covering up, away from the laptop and set aside.
      Ask FixBot
    8. Toshiba Satellite 1805-S177 Screen Replacement: step 24, image 1 of 2 Toshiba Satellite 1805-S177 Screen Replacement: step 24, image 2 of 2
      • Using your fingers, pinch the black modem piece, lift and slide the modem up and move it aside.
      • The modem is connected to a red and black wire.
      Ask FixBot
    9. Toshiba Satellite 1805-S177 Screen Replacement: step 25, image 1 of 1
      • Using a Phillips screwdriver, unscrew and remove one F6 screw from beneath the modem.
      Ask FixBot
    10. Toshiba Satellite 1805-S177 Screen Replacement: step 26, image 1 of 3 Toshiba Satellite 1805-S177 Screen Replacement: step 26, image 2 of 3 Toshiba Satellite 1805-S177 Screen Replacement: step 26, image 3 of 3
      • Using a Phillips screwdriver, unscrew and remove 5 B20 screws, located along the corners of the bottom of the laptop.
      Ask FixBot
    11. Toshiba Satellite 1805-S177 Screen Replacement: step 27, image 1 of 3 Toshiba Satellite 1805-S177 Screen Replacement: step 27, image 2 of 3 Toshiba Satellite 1805-S177 Screen Replacement: step 27, image 3 of 3
      • Using a Phillips screwdriver, unscrew and remove 3 B25 screws from the bottom of the laptop.
      Ask FixBot
    12. Toshiba Satellite 1805-S177 Screen Replacement: step 28, image 1 of 3 Toshiba Satellite 1805-S177 Screen Replacement: step 28, image 2 of 3 Toshiba Satellite 1805-S177 Screen Replacement: step 28, image 3 of 3
      • Using a Phillips screwdriver, unscrew and remove 3 F6 screws from the bottom of the laptop.
      Ask FixBot
    13. Toshiba Satellite 1805-S177 Screen Replacement: step 29, image 1 of 3 Toshiba Satellite 1805-S177 Screen Replacement: step 29, image 2 of 3 Toshiba Satellite 1805-S177 Screen Replacement: step 29, image 3 of 3
      • Using a Phillips screwdriver, unscrew and remove 3 F4 screws from the battery area of the laptop.
      Ask FixBot
    14. Toshiba Satellite 1805-S177 Screen Replacement: step 30, image 1 of 2 Toshiba Satellite 1805-S177 Screen Replacement: step 30, image 2 of 2
      • Lift open the screen of the laptop and, using your fingers and the guides on the side of the laptop, push up on the top plastic covering of the laptop, moving from one side of the laptop to the other.
      Ask FixBot
    15. Toshiba Satellite 1805-S177 Screen Replacement: step 31, image 1 of 2 Toshiba Satellite 1805-S177 Screen Replacement: step 31, image 2 of 2
      • Setting screen next to the base of the laptop, pinch the connecting cable with your fingers and gently pull connecting cable from monitor.
      Ask FixBot
2 other people completed this guide.
Hannah
251 Reputation
7 Guides authored
Cal Poly, Team 3-5, Johann Summer 2010 Member of Cal Poly, Team 3-5, Johann Summer 2010
CPSU-JOHANN-R10S3G5
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 32
Past 30 Days: 115
All Time: 3,980
