Shop the Holiday Gift Guide
Canon PowerShot A75 Casing Replacement
Views: 2.2K
View statistics:
Past 24 Hours:
6
Past 7 Days:
18
Past 30 Days:
56
All Time:
2,205
Comments: 1
1 guide comment.
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 2 - 5 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Use this guide to replace the Canon Powershot A75's casing.
Tools
    1. Canon PowerShot A75 Casing Replacement, Batteries: step 1, image 1 of 1
      • Turn the camera over and locate the "BATT OPEN" sliding switch.
      Ask FixBot
    2. Canon PowerShot A75 Casing Replacement: step 2, image 1 of 3 Canon PowerShot A75 Casing Replacement: step 2, image 2 of 3 Canon PowerShot A75 Casing Replacement: step 2, image 3 of 3
      • Slide the switch to the right.
      • The battery cover should slide down and spring open.
      Ask FixBot
    3. Canon PowerShot A75 Casing Replacement: step 3, image 1 of 3 Canon PowerShot A75 Casing Replacement: step 3, image 2 of 3 Canon PowerShot A75 Casing Replacement: step 3, image 3 of 3
      • Remove the 4 AA batteries.
      • Watch for the orientation of the batteries as they slide out.
      • The battery orientation is shown under the battery flap itself and on a sticker next to the battery flap.
      Ask FixBot
    1. Canon PowerShot A75 Casing Replacement, Casing: step 4, image 1 of 1
      • Remove the three 2.5mm screws on the bottom of the camera.
      Ask FixBot
    2. Canon PowerShot A75 Casing Replacement: step 5, image 1 of 1
      • Remove the 3.8mm screw underneath the flap that covers the A/V port.
      Ask FixBot
    3. Canon PowerShot A75 Casing Replacement: step 6, image 1 of 2 Canon PowerShot A75 Casing Replacement: step 6, image 2 of 2
      • Remove the 2.4mm screw located underneath the cover of the memory card slot.
      Ask FixBot
    4. Canon PowerShot A75 Casing Replacement: step 7, image 1 of 2 Canon PowerShot A75 Casing Replacement: step 7, image 2 of 2
      • Open the memory card slot by sliding it laterally until you hear a click.
      • Remove the 5.9mm screw in the upper corner of the memory card slot.
      Ask FixBot
    5. Canon PowerShot A75 Casing Replacement: step 8, image 1 of 1
      • Remove the two 4.1mm screws at the bottom of the battery flap.
      Ask FixBot
    6. Canon PowerShot A75 Casing Replacement: step 9, image 1 of 2 Canon PowerShot A75 Casing Replacement: step 9, image 2 of 2
      • Lift the shutter button and speaker part from the top of the camera.
      • DO NOT pull the part too hard because there is a plug connecting the speaker to the camera.
      Ask FixBot
    7. Canon PowerShot A75 Casing Replacement: step 10, image 1 of 3 Canon PowerShot A75 Casing Replacement: step 10, image 2 of 3 Canon PowerShot A75 Casing Replacement: step 10, image 3 of 3
      Tool used on this step:
      Buy
      • Using a pair of tweezers, grab the plug that connects the speaker to the camera and gently pull it out.
      Ask FixBot
    8. Canon PowerShot A75 Casing Replacement: step 11, image 1 of 1
      • Remove the rightmost 4.2mm screw underneath the battery cover, not the center screw.
      Ask FixBot
    9. Canon PowerShot A75 Casing Replacement: step 12, image 1 of 3 Canon PowerShot A75 Casing Replacement: step 12, image 2 of 3 Canon PowerShot A75 Casing Replacement: step 12, image 3 of 3
      • Separate the back casing and front casing of the camera using your hands.
      • Pulling the two halves apart can be difficult, especially at the top. Use a moderate amount of force.
      Ask FixBot
    10. Canon PowerShot A75 Casing Replacement: step 13, image 1 of 3 Canon PowerShot A75 Casing Replacement: step 13, image 2 of 3 Canon PowerShot A75 Casing Replacement: step 13, image 3 of 3
      • On the front of the camera, press the button on the lower left of the lens.
      • Twist the outer lens casing counter-clockwise and slide it out.
      Ask FixBot
    11. Canon PowerShot A75 Casing Replacement: step 14, image 1 of 3 Canon PowerShot A75 Casing Replacement: step 14, image 2 of 3 Canon PowerShot A75 Casing Replacement: step 14, image 3 of 3
      • Take off the front casing.
      • There is a black rubber washer around the lens that comes out after you take the casing off. Make sure to replace it when putting the camera back together.
      Ask FixBot
4 other people completed this guide.
Author
with
Andrew Elliott
13 Reputation
1 Guide authored
Cal Poly, Team 17-30, Amido Spring 2012 Member of Cal Poly, Team 17-30, Amido Spring 2012
CPSU-AMIDO-S12S17G30
5 Members
72 Guides authored
1 Guide Comment
Thank you for this detailed guide. It helped me to gain access to the electrical contacts in the battery compartment to remove alkaline battery corrosion
Jef B - Reply Share
Past 24 Hours: 6
Past 7 Days: 18
Past 30 Days: 56
All Time: 2,205
