Shop the Holiday Gift Guide
XBOX Controller S Trigger Replacement
Views: 1.2K
View statistics:
Past 24 Hours:
5
Past 7 Days:
44
Past 30 Days:
144
All Time:
1,158
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
If the trigger on your Xbox Controller S is unresponsive or difficult to press, use this guide to replace it. The trigger is used to perform in-game actions, such as aiming or firing a weapon. Step 4 requires desoldering to remove the trigger from the motherboard.
Tools
    1. XBOX Controller S Trigger Replacement, Shell: step 1, image 1 of 1
      • Remove the seven 9.4 mm screws on the back of the controller using a Phillips #00 screwdriver.
      • One screw is hidden behind the sticker on the back of the controller. Peel that sticker back and remove that screw as well.
      Ask FixBot
    2. XBOX Controller S Trigger Replacement: step 2, image 1 of 3 XBOX Controller S Trigger Replacement: step 2, image 2 of 3 XBOX Controller S Trigger Replacement: step 2, image 3 of 3
      • Keep the controller facing down to prevent components from falling out.
      • Remove the back shell.
      • Flip the controller over and remove the front shell.
      Ask FixBot
    1. XBOX Controller S Trigger Replacement, Trigger: step 3, image 1 of 2 XBOX Controller S Trigger Replacement, Trigger: step 3, image 2 of 2
      • Carefully remove the motherboard from the shell.
      Ask FixBot
    2. XBOX Controller S Trigger Replacement: step 4, image 1 of 3 XBOX Controller S Trigger Replacement: step 4, image 2 of 3 XBOX Controller S Trigger Replacement: step 4, image 3 of 3
      • Desolder the three attachment points for the trigger, then unclip the trigger from the circuit board.
      • Clip in the new replacement trigger and solder the three attachment points.
      Ask FixBot
Author
with
WyattGripp
345 Reputation
3 Guides authored
Texas Tech, Team 46-5, Johansen Fall 2025 Member of Texas Tech, Team 46-5, Johansen Fall 2025
TTU-JOHANSEN-F25S46G5
4 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 44
Past 30 Days: 144
All Time: 1,158
