Up to 20% off select tools
XBOX Controller S Shell Replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
28
Past 30 Days:
137
All Time:
761
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
If your Xbox Controller S shell is cracked, use this guide to replace it. The shell is what protects the circuit board from damage.
    1. XBOX Controller S Shell Replacement, Shell: step 1, image 1 of 1
      • Remove the seven 9.4 mm screws on the back of the controller using a Phillips #00 screwdriver.
      • One screw is hidden behind the sticker on the back of the controller. Peel that sticker back and remove that screw as well.
      Ask FixBot
    2. XBOX Controller S Shell Replacement: step 2, image 1 of 3 XBOX Controller S Shell Replacement: step 2, image 2 of 3 XBOX Controller S Shell Replacement: step 2, image 3 of 3
      • Keep the controller facing down to prevent components from falling out.
      • Remove the back shell.
      • Flip the controller over and remove the front shell.
      Ask FixBot
Author
with
WyattGripp
345 Reputation
3 Guides authored
Texas Tech, Team 46-5, Johansen Fall 2025 Member of Texas Tech, Team 46-5, Johansen Fall 2025
TTU-JOHANSEN-F25S46G5
4 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 28
Past 30 Days: 137
All Time: 761
