Introduction
Go to step 1 ↓If your Xbox Controller S cable isn't working, use this guide to replace the cable. The cable is what allows the controller to be connected to the console. Steps 4 and 5 require you to use a soldering iron. This video link will be helpful for your device repair
Parts
Tools
Remove the seven 9.4 mm screws on the back of the controller using a Phillips #00 screwdriver.
Pop the circuit board out of the rear housing to access the cord.
Note the order of the wires that are connected from the cable to the circuit board. These wires will need to be put back in the same configuration.
Desolder the connector points from the opposite side of the board. Go back and push down on all the pins to push them out of the holes.
If it doesn't come loose, reheat and remove some additional solder from the points on the board.
Clean up the area when you are done with some 99% IPA (isopropyl alcohol).
