Introduction
The rear motor drives the power to the rear wheels of the car. It is one of the more complex parts of the car that takes time to get to. If the car isn't sending power to the wheels, then this replacement guide is the key.
Unscrew the two 2.5mm Phillips #00 screws from the middle of the car.
Unclip the two clips to remove the battery cover.
Lift the main underbody from the shell of the car.
Lift up the body to expose the wiring and hardware underneath.
Unscrew the two 2.5mm Phillips #00 screws on the white covering of the rear motor casing.
There is a plastic casing over the rear motor. Simply remove this plastic covering and proceed.
