Introduction
The front steering motor provides power to the steering column which turns the wheels to one side. If the car fails to turn to one side or the other, it is possible the front steering motor needs replacement.
Unscrew the two 2.5mm Phillips #00 screws from the middle of the car.
Unclip the two clips to remove the battery cover.
Lift the main underbody from the shell of the car.
Lift up the body to expose the wiring and hardware underneath.
Remove the three 1.6mm Phillips #000 screws from the black motor casing
Remove the remaining three 1.6 mm Phillips #000 screws from the black motor casing
The second image shows the screws removed from the casing.
