Wolf Gourmet WGBL100S Blades Replacement
  1. Wolf Gourmet WGBL100S Blades Replacement, Blender Blades: step 1, image 1 of 1
    • Flip over the pitcher to expose the base of the blade assembly.
    • Using the H4.0 Allen key from the 54 bit driver kit, attached to an impact driver, remove the socket head cap screw from the drive coupling.
    • Apply a solvent to remove adhesive if necessary.
  2. Wolf Gourmet WGBL100S Blades Replacement: step 2, image 1 of 1
    • Using a pair of pliers, pull of the drive shaft coupling.
  3. Wolf Gourmet WGBL100S Blades Replacement: step 3, image 1 of 2 Wolf Gourmet WGBL100S Blades Replacement: step 3, image 2 of 2
    • Using a flat head screwdriver and a mallet, bend down the two tabs holding the large nut.
  4. Wolf Gourmet WGBL100S Blades Replacement: step 4, image 1 of 1
    • Remove the nut using a crescent wrench.
  5. Wolf Gourmet WGBL100S Blades Replacement: step 5, image 1 of 1
    • Push the blade assembly into the jar.
    • Remove the blades from the device.
    • Be careful not to cut yourself when handling the blades.
Luke Kutz
354 Reputation
3 Guides authored
Cal Poly, Team S25-G16, Maness Spring 2018 Member of Cal Poly, Team S25-G16, Maness Spring 2018
CPSU-MANESS-S18S25G16
4 Members
5 Guides authored
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 14
All Time: 781
