Shop the Holiday Gift Guide
Withings ScanWatch: Reattach the Loose Sensor Cover
Views: 12K
View statistics:
Past 24 Hours:
15
Past 7 Days:
110
Past 30 Days:
478
All Time:
11,709
Comments: 6
3 comments on steps, 3 guide comments.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 minutes
Difficulty: Moderate
Needs More Images
A few more images would make this guide's procedures crystal clear.
Community-Contributed Guide
Introduction
Go to step 1 ↓
This guide shows how to reattach the loose sensor cover on a Withings ScanWatch after the watch has been opened.
Parts
Tools
    1. Withings ScanWatch: Reattach the Loose Sensor Cover, Open the Case: step 1, image 1 of 1
      • The watch is held together by friction and a thin black gasket. There are no screws or glue.
      • Place a thin metal smartphone opening tool between the metal case and the glass/display side of the watch, not on the sensor side.
      • Work your way around the watch carefully to release the gasket.
      Ask FixBot
    2. Withings ScanWatch: Reattach the Loose Sensor Cover, Disconnect the Sensor Cable: step 2, image 1 of 1
      • Once the watch is open, you can see the movement and a small cable connecting the sensor to it.
      • The cable has an iPhone-like connector and can be released with a plastic spudger.
      • Carefully pry the connector straight up to avoid damage.
      • Do not pull on the cable. Disconnect the connector first.
      Ask FixBot
    1. Withings ScanWatch: Reattach the Loose Sensor Cover, Clean the bonding surfaces: step 3, image 1 of 3 Withings ScanWatch: Reattach the Loose Sensor Cover, Clean the bonding surfaces: step 3, image 2 of 3 Withings ScanWatch: Reattach the Loose Sensor Cover, Clean the bonding surfaces: step 3, image 3 of 3
      • Remove any old adhesive residue from the case and sensor cover.
      • Clean both surfaces with isopropyl alcohol and a cotton swab.
      • Do not scratch the glass or sensor area.
      Ask FixBot
      • Apply a thin, even layer of adhesive around the edge.
      • Keep adhesive away from the sensor opening and the crown.
      • Less adhesive is better here.
      Ask FixBot
      • Set the sensor cover straight into the case.
      • Press it evenly until it sits flush.
      • Check that the crown still moves freely.
      • Stop if the cover tilts or sits unevenly.
      Ask FixBot
      • Hold the watch with light pressure until the adhesive sets.
      • Let the repair cure completely.
      • Check the crown and sensors after curing.
      • Water resistance is not guaranteed after this repair.
      • For more on water resistance, see the Withings help page: Withings help on water resistance.
      Ask FixBot
Let the adhesive fully cure, then reassemble the watch. If the back case keeps coming loose or you see moisture inside the watch, check the Withings exchange program for affected ScanWatch HWA09 devices: Withings exchange program. If you have more questions, ask our Answers community.
3 other people completed this guide.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Author
with
Uhrmacherfreund
148 Reputation
1 Guide authored
3 Guide Comments
Ich hab es ähnlich gemacht. Mittlerweile den 3. Versuch.
1. Versuch mit Sekundenkleber nur von außen
2. Auch von Außen mit einem Dauerelastischen Kleber
3. Versuch von innen mit KFZ Gehäusedichtmasse
Alle Versuche von außen waren leider erfolglos, da auf dem polierten Edelstahlgehäuse kein Kleber ordentlich hällt.
Mit der Dichtmasse hält bis jetzt am längsten.
Oliver - Reply Share
The markers, three of them, on my Withings came loose when I dropped the watch. No issues with the crystal. Withings won't fix it or suggest repair facility. Their solution, 25% discount on the next watch purchase and recycle the item. I was like, 'but it still works! It just three markers the came unglued!' Bye.
DoxYDox DeLamanca - Reply Share
ScanWatch
Would not charge
Contacted Withings
over an hour
after sending them photos of detached back case
and they keep asking delay tactics
refuse to escalate support ticket
they keep saying we cannot find your account, device
app keeps showing errors
NEVER BUY ANYTHING FROM THIS FRENCH COMPANY
as bad as Google Fitbit. Switched from fitbit to withings.
BIG MISTAKE
BOTH NASTY
YMMV
mapatouli - Reply Share
Past 24 Hours: 15
Past 7 Days: 110
Past 30 Days: 478
All Time: 11,709
