Withings ScanWatch (Gen 1): Open the Case
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. Withings ScanWatch (Gen 1): Open the Case, Open the Case: step 1, image 1 of 1
      • The watch is held together by friction and a thin black gasket. There are no screws or glue.
      • Place a thin metal smartphone opening tool between the metal case and the glass/display side of the watch, not on the sensor side.
      • Work your way around the watch carefully to release the gasket.
      Ask FixBot
    2. Withings ScanWatch (Gen 1): Open the Case, Disconnect the Sensor Cable: step 2, image 1 of 1
      • Once the watch is open, you can see the movement and a small cable connecting the sensor to it.
      • The cable has an iPhone-like connector and can be released with a plastic spudger.
      • Carefully pry the connector straight up to avoid damage.
      • Do not pull on the cable. Disconnect the connector first.
      Ask FixBot
The watch is open and the sensor cable is disconnected.
Cäsh
7 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 9
All Time: 57
