Wire Sunglasses Frame Lens Replacement
  1. Wire Sunglasses Frame Lens Replacement, Sunglasses Lens: step 1, image 1 of 2 Wire Sunglasses Frame Lens Replacement, Sunglasses Lens: step 1, image 2 of 2
    • Place the missing lens against the upper rim of the glasses, feel free to fit the bottom wire underneath.
    Ask FixBot
  2. Wire Sunglasses Frame Lens Replacement: step 2, image 1 of 2 Wire Sunglasses Frame Lens Replacement: step 2, image 2 of 2
    • While holding the frame in position, thread the plastic strip around the metal wire. The strip should sit around halfway through it.
    Ask FixBot
  3. Wire Sunglasses Frame Lens Replacement: step 3, image 1 of 2 Wire Sunglasses Frame Lens Replacement: step 3, image 2 of 2
    • Using the plastic strip as an anchor, slowly re-fasten the wire underneath the bottom of the frame. Slide the strip from one end of the frame to the other.
    • The lens must remain firmly around the upper rim for the wire to slide underneath.
    Ask FixBot
  4. Wire Sunglasses Frame Lens Replacement: step 4, image 1 of 2 Wire Sunglasses Frame Lens Replacement: step 4, image 2 of 2
    • Once the wire is under the frame, use the plastic strip to gently adjust the wire as needed.
    Ask FixBot
  5. Wire Sunglasses Frame Lens Replacement: step 5, image 1 of 2 Wire Sunglasses Frame Lens Replacement: step 5, image 2 of 2
    • Once you are done, begin to remove the plastic strip from the frame.
    • Gently tug at one end of the strip to remove it from between the lens and the wire.
    Ask FixBot
  6. Wire Sunglasses Frame Lens Replacement: step 6, image 1 of 2 Wire Sunglasses Frame Lens Replacement: step 6, image 2 of 2
    • Ensure the lens is secured by gently pushing it.
    • If the lens is still loose or needs to be re-adjusted, take the lens out and start again from Step 1.
    Ask FixBot
Following these steps will help save time and money so you can continue enjoying your shades.
Violet Lampman
133 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 7
Past 30 Days: 44
All Time: 516
