Windsor Willow Chain Replacement
  1. Windsor Willow Chain Replacement, Chain: step 1, image 1 of 1
    • The chain connects the crank arm to the gear cluster on the back wheel.
  2. Windsor Willow Chain Replacement: step 2, image 1 of 1
    • On the chain, locate the Master Chain. It is a lighter gray than the other links of the chain. This is how you can break the chain for easier removal.
  3. Windsor Willow Chain Replacement: step 3, image 1 of 2 Windsor Willow Chain Replacement: step 3, image 2 of 2
    • To separate the Master Link, hold the left side of the link in your left hand and the link to the right in your right hand. Push the two links together to enable the release. Pull the links apart, one hand moving towards yourself and the other away from you. This will separate the links of the chain.
  4. Windsor Willow Chain Replacement: step 4, image 1 of 1
    • Once you have separated the links of the chain, pull down on the right side of the chain as shown. Pull until the chain has been fully removed from the gears. Place the chain on a paper towel or cloth to prevent getting grease anywhere.
Stuart Ross
225 Reputation
2 Guides authored
Cal Poly, Team 10-6, Banghart Winter 2017 Member of Cal Poly, Team 10-6, Banghart Winter 2017
CPSU-BANGHART-W17S10G6
5 Members
6 Guides authored
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 5
All Time: 73
