Window Screen Mesh Replacement
  1. Window Screen Mesh Replacement, Mesh: step 1, image 1 of 3 Window Screen Mesh Replacement, Mesh: step 1, image 2 of 3 Window Screen Mesh Replacement, Mesh: step 1, image 3 of 3
    • Find the place in the channel of the screen frame where the ends of the spline meet.
    • The channel is the deep, narrow line in one side of the frame, and spline is the plastic cord.
    • Use a screwdriver to pry out an end of the spline.
    • After removing a couple inches of the spline, hold the spline with a hand and pull all of the spline out of the channel.
  2. Window Screen Mesh Replacement: step 2, image 1 of 2 Window Screen Mesh Replacement: step 2, image 2 of 2
    • Starting at an edge of the screen mesh, pull it upward to remove the mesh from the frame.
  3. Window Screen Mesh Replacement: step 3, image 1 of 2 Window Screen Mesh Replacement: step 3, image 2 of 2
    • Clean the frame using a warm, wet washcloth to remove dirt and debris.
  4. Window Screen Mesh Replacement: step 4, image 1 of 2 Window Screen Mesh Replacement: step 4, image 2 of 2
    • Hold down the edge of the screen mesh roll with one hand on a side of the frame.
    • Roll out the mesh over the top of the frame.
    • The mesh should be large enough to be at least an inch larger than the edge of the frame on each side.
  5. Window Screen Mesh Replacement: step 5, image 1 of 3 Window Screen Mesh Replacement: step 5, image 2 of 3 Window Screen Mesh Replacement: step 5, image 3 of 3
    • Use a pair of scissors or a utility knife to cut off from the roll of mesh, leaving around an extra inch outward from the frame.
    • A utility knife is better for making precise cuts.
    • Trim the other sides of the mesh, also leaving around an inch over the edges of the frame.
  6. Window Screen Mesh Replacement: step 6, image 1 of 3 Window Screen Mesh Replacement: step 6, image 2 of 3 Window Screen Mesh Replacement: step 6, image 3 of 3
    • Cut off the corners of the mesh diagonally and leave a bit of extra mesh over the frame.
    • Be careful not to cut too far into the mesh, or it will leave holes in the corners of the screen when it's finished.
  7. Window Screen Mesh Replacement: step 7, image 1 of 3 Window Screen Mesh Replacement: step 7, image 2 of 3 Window Screen Mesh Replacement: step 7, image 3 of 3
    • Hold the mesh down firmly with one hand.
    • Use the convex side of the screen rolling tool to press the mesh down into the channels.
    • The convex disc on one side of the roll bulges outward, and the concave disc on the other side caves inward.
    • Using the screen rolling tool, press the mesh into the frame channel on all sides of the frame.
    • Keep the mesh in the same place and stretch it as best as possible so the mesh will end up tight on the frame.
  8. Window Screen Mesh Replacement: step 8, image 1 of 3 Window Screen Mesh Replacement: step 8, image 2 of 3 Window Screen Mesh Replacement: step 8, image 3 of 3
    • Align the tip of a roll of spline to a corner of the frame.
    • Use the concave side of the screen rolling tool to press the end of the spline roll down into the channel.
    • Press and roll the concave side of the screen rolling tool down the channel.
  9. Window Screen Mesh Replacement: step 9, image 1 of 2 Window Screen Mesh Replacement: step 9, image 2 of 2
    • Press the spline to the edge of the corner.
    • Pull the spline to line up with the perpendicular channel
    • Press down and roll the spline into the new channel.
    • To get the spline in the corners, push it down with the screwdriver.
  10. Window Screen Mesh Replacement: step 10, image 1 of 2 Window Screen Mesh Replacement: step 10, image 2 of 2
    • After pushing spline into the frame channel on all sides, cut the end of the spline.
  11. Window Screen Mesh Replacement: step 11, image 1 of 2 Window Screen Mesh Replacement: step 11, image 2 of 2
    • Press and roll down the end of the spline into the channel.
    • Trim the spline shorter if it is too long to fit into the corner.
  12. Window Screen Mesh Replacement: step 12, image 1 of 2 Window Screen Mesh Replacement: step 12, image 2 of 2
    • Cut off the excess mesh with the pair of scissors or utility knife.
    • Don't rip a hole or tear with the scissors or utility knife while trimming.
If the screen mesh isn't tight enough or there are other issues, return to the beginning of the steps and restart. You don't have to do all of the steps if you are doing a minor revision, however, like only taking the spline out in order to tighten the screen mesh and placing the spline back afterwards.
2 other people completed this guide.
2 Guide Comments
I think I tried too hard to get the mesh really taught. I was replacing the regular type screen with a thicker, stronger cat-resistent mesh. The two screens are so tight the mesh pulls the frame so that it doesn't lay flat but twists, making installation far more challenging than it needs to be.
SJ Astra - Reply Share
One piece of advice is to bring a piece of the old spline with you to the hardware store when you buy the new spline so you can get the correct size. I didn’t realize how many sizes there are!
Meredith Guthrie - Reply Share
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 69
All Time: 4,425
