Introduction
Follow this guide to replace the touch screen and other components inside the phone
Heat the phone with a 80-degree plate or with an appropriate dryer
With the help of tools or special thin wire begin to separate from the touch glass display
Utmost care not to break the display, be sure to insert between the touch screen display instruments and not between glass and touch screen ..
There are no flat key is therefore the only attention to the display
To assemble the device, follow these instructions in reverse order.
8 other people completed this guide.
Special thanks to these translators:
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
4 Comments
I replaced a screen on a Acer Wiko Lenny 2 - was very simular to this one. I followed all these steps and it is working BUT the display does not respond as it should. Almost all touches on the outside border of the screen (for example, digit 1 on the left, digit 0 on the right) don't respond quickly, or don't respond at all. What could be wrong? If wonder if I didn't clean the digitizer properly enough...
sorry for the delay.
I had some problem with the touch screen too much more intrusive than yours.
I have secured the edges well with scotch because it does not contact me.
But these Chinese touchscreens do not have good quality so I prefer to buy a screen mounted with touchscreen, so I save a lot of time and work is better and working
Ciao, come fai a rimuovere i residui di colla dal display, una volta tolto il vetro?
