How do I replace a brittle or broken shock cord?
  1. How do I replace a brittle or broken shock cord?, shock cord: step 1, image 1 of 1
    • First, check if you really need to replace the cord. The following criteria can be helpful in your decision: cord has lost, elasticity, rough surfaces. damaged areas
    • Put all segments together so that you have one long tent pole.
  2. How do I replace a brittle or broken shock cord?: step 3, image 1 of 3 How do I replace a brittle or broken shock cord?: step 3, image 2 of 3 How do I replace a brittle or broken shock cord?: step 3, image 3 of 3
    • Pull out the end pin on one side and cut off the knot. Then pull the shock cord out completely from the other end of the pole.
  3. How do I replace a brittle or broken shock cord?: step 4, image 1 of 1
    • Attach the new shock cord to the pin and tie a knot in it.
  4. How do I replace a brittle or broken shock cord?: step 5, image 1 of 1
    • Thread the loose shock cord end through the tent pole.
  5. How do I replace a brittle or broken shock cord?: step 6, image 1 of 1
    • When the shock cord is hanging out of the tent pole with a fair amount of excess, insert the pin back into the pole at the other end.
  6. How do I replace a brittle or broken shock cord?: step 7, image 1 of 1
    • At the other end, pull the shock cord taught – with about one arm’s length of tension in the cord.
    • In order to keep this tension for the next step, hold the shock cord to the pole with your fingers.
    • Hold the shock cord and tension with the help of a clothes pin.
    • Now attach the end pin to this side of the shock cord, tie a knot in it, and insert it into the pole.
Done! You made it.
Special thanks to these translators:
de en
100%
VAUDE Reparaturteam is helping us fix the world! Want to contribute?
Start translating ›
VAUDE Reparaturteam
6,255 Reputation
32 Guides authored
Vaudesport Member of Vaudesport
Community
3 Members
96 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 35
All Time: 1,976
