This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Community-Contributed Guide
Introduction
Go to step 1 ↓This guide shows you how to replace the screen of a Why! NH57ADS, which is glued to the housing and connected via a connector cable.
Remove the two screws holding the battery in place.
Slip your finger into the finger hole provided at the top of the battery.
...and lift to remove it
Remove the frame.
Unstick the screen at all 4 corners as gently as possible. Caution, the adhesive is strong, so be careful not to break the screen.
The orange rectangles represent the approximate location of the adhesive strips, which can be seen more clearly on the back of the screen.
The yellow rectangle indicates the screen connector cable.
