Shop the Holiday Gift Guide
This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Why! NH57ADS Keyboard Disassembly
View statistics:
Past 24 Hours:
4
Past 7 Days:
18
Past 30 Days:
80
All Time:
738
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 3 minutes
Difficulty: Easy
Community-Contributed Guide
Introduction
Go to step 1 ↓
This guide shows you how to disassemble the keyboard of an NH57ADS, once the lower case is removed.
    1. Why! NH57ADS Keyboard Disassembly, Battery: step 1, image 1 of 3 Why! NH57ADS Keyboard Disassembly, Battery: step 1, image 2 of 3 Why! NH57ADS Keyboard Disassembly, Battery: step 1, image 3 of 3
      • Remove the two screws holding the battery in place.
      • Slip your finger into the finger hole provided at the top of the battery.
      • ...and lift to remove it
      Ask FixBot
    1. Why! NH57ADS Keyboard Disassembly, Bottom Cover: step 2, image 1 of 3 Why! NH57ADS Keyboard Disassembly, Bottom Cover: step 2, image 2 of 3 Why! NH57ADS Keyboard Disassembly, Bottom Cover: step 2, image 3 of 3
      • Remove the five Phillips screws securing the bottom to the case.
      • Slide the cover up slightly to release the clips holding it in place. This is the view on the right. The mark on the cover should now line up with the second mark on the case of the computer.
      Ask FixBot
    2. Why! NH57ADS Keyboard Disassembly, Removing the Bottom Cover: step 3, image 1 of 3 Why! NH57ADS Keyboard Disassembly, Removing the Bottom Cover: step 3, image 2 of 3 Why! NH57ADS Keyboard Disassembly, Removing the Bottom Cover: step 3, image 3 of 3
      • This is the view on the left before and after sliding the cover. The mark on the cover should now line up with the second mark on the case of the computer.
      • Slide the bottom cover to remove it.
      Ask FixBot
    1. Why! NH57ADS Keyboard Disassembly, Keyboard: step 4, image 1 of 3 Why! NH57ADS Keyboard Disassembly, Keyboard: step 4, image 2 of 3 Why! NH57ADS Keyboard Disassembly, Keyboard: step 4, image 3 of 3
      Tool used on this step:
      iFixit Opening Picks (Set of 6)
      $4.95
      Buy
      • Remove the two Phillips screws with the keypad symbol next to them.
      • Insert an iFixit opening pick into the upper slot of the keyboard and slide it to the end.
      Ask FixBot
    2. Why! NH57ADS Keyboard Disassembly, Remove the Keyboard: step 5, image 1 of 3 Why! NH57ADS Keyboard Disassembly, Remove the Keyboard: step 5, image 2 of 3 Why! NH57ADS Keyboard Disassembly, Remove the Keyboard: step 5, image 3 of 3
      • Carefully lift the keyboard.
      • Gently flip up the retaining latch on the black keyboard cable and slide it out of the connector.
      • Repeat with the (orange) backlight cable.
      Ask FixBot
To reassemble your device, follow the instructions in reverse order.
Special thanks to these translators:
fr en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Author
with
Felice Suglia
33,634 Reputation
283 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 18
Past 30 Days: 80
All Time: 738
