This translation may not reflect the most recent updates from the source guide. Help update the translation or view the source guide.
Remove the two screws holding the battery in place.
Slip your finger into the finger hole provided at the top of the battery.
...and lift to remove it
Remove the five Phillips screws securing the bottom to the case.
Slide the cover up slightly to release the clips holding it in place. This is the view on the right. The mark on the cover should now line up with the second mark on the case of the computer.
This is the view on the left before and after sliding the cover. The mark on the cover should now line up with the second mark on the case of the computer.
Slide the bottom cover to remove it.
Remove the three Phillips screws securing the fan on the right.
Carefully unplug the fan's power connector.
Remove the first fan.
Remove the two Phillips screws securing the left hand fan.
Remove the six Phillips heatsink retaining screws .
Using the two black tabs as handles, lift and remove the heatsink.
To reassemble your device, follow the instructions in reverse order.
Special thanks to these translators:
83%
These translators are helping us fix the world! Want to contribute?
Start translating ›
