Introduction
Go to step 1 ↓A stuck washplate (also called a wash plate, pulsator, or agitator plate) can keep you from accessing the hub and can cause poor washing performance if it can’t move freely. This guide walks through progressively stronger, lower-risk ways to loosen and remove a stubborn Whirlpool-built washplate using cleaning chemistry, test cycles, and careful lifting techniques.
Step 1 Prepare for safe work
Unplug the washer before disassembly and keep the plug out of reach.
Turn off the water supply valves if you plan to swap hoses or work with the lid open for an extended time.
Step 2 Remove the center cap
Use a flathead screwdriver to pry up and remove the center cap from the wash plate.
Step 3 Remove the wash plate bolt
Use a ratchet with a 16 mm or 7/16 inch socket to remove the center bolt from the wash plate.
Use an impact gun if the bolt is seized and a hand ratchet will not break it free.
Step 4 Add citric acid
Pour about 1 to 1.5 cups of citric acid powder into the tub.
Fill the tub with hot water to help loosen debris and buildup under the wash plate.
Step 5 Choose a cycle method to loosen the plate
Run a regular wash cycle with the hottest water setting available to help the citric acid work under the washplate.
Fill the tub with hot water and use the washer’s test mode if you want agitation or spin without quickly pumping out the citric-acid water.
Run a cold cycle with the hot and cold supply lines swapped if the washer won’t request hot water in the mode you need.
Step 6 Bypass the lid lock for monitoring
Use a Torx screwdriver to remove the lid-lock striker from the lid.
Insert the striker into the lid lock only long enough to monitor the tub with the lid open during testing.
Step 7 Run a test cycle
Enter the washer's service test system and select a manual test mode.
Engage the lid lock in test mode, since agitation and spin will not run without it.
Select a gentle mode and press Start to begin agitation.
Repeat the agitation test as needed, since it usually runs for only about a minute at a time.
Press Start to stop the test and switch to spin mode or another mode when needed.
Step 8 Drain the dirty water before prying
Use a drain mode to pump out the dirty citric-acid water before attempting removal.
Wipe off splashed debris from the lid and rim so it doesn’t fall back into the tub while you work.
Step 9 Pull upward with a spring tool
Use a trampoline spring tool to hook into the wash plate's plastic holes or edges and pull upward.
File the tool's tip slightly if needed so it fits and grips the plastic better.
Work around the wash plate, pulling from different points instead of yanking from one side.
Step 10 Free a stubborn wash plate
Try sliding a putty knife under the wash plate if you need a thinner tool, but expect limited grip on some plates.
Refill the tub with water and add more citric acid at a lower concentration if the plate is still stuck.
Repeat agitation and spin test runs to loosen the plate gradually instead of forcing it off in one attempt.
Step 11 Rock the wash plate loose
Add more citric acid and orange degreaser to the tub if buildup is still binding the plate.
Roll the liquid around the tub and rock the wash plate back and forth until it breaks free.
Step 12 Remove the wash plate and clean up
Lift the wash plate out of the tub once it releases.
Inspect and clean the area under the wash plate, since the citric acid should have loosened and floated debris.
Repair didn't go as planned? Ask our Answers community for help.
