Introduction
Go to step 1 ↓The dispenser drawer, also called the detergent drawer or dispensing drawer, holds detergent and fabric conditioner before it enters the wash. Over time, detergent residue, conditioner residue, mold, and residue can build up and wash into clothes. Use this guide to remove, clean, and refit the drawer, clean the drawer cavity, check the drum rubber, and run a hot empty wash. This guide was written using a Whirlpool integrated washing machine, and other Whirlpool models may have minor differences.
Tools
Nitrile Disposable GlovesOptional
Step 1 Prepare the washer
Remove any laundry and make sure no wash cycle is running.
Wear protective gloves if you have sensitive skin or see mold in the drawer area.
Set a cleaning cloth, hot, soapy water, and an brush near the washer.
Step 2 Remove the dispenser drawer
Pull the detergent drawer out gently from the top left corner until it stops.
Press down the release clip at the fabric softener level indicator.
Keep the release clip pressed and pull the whole dispenser drawer straight out.
Step 3 Clean the dispenser drawer cavity
Look inside the dispenser drawer opening for detergent residue, fabric softener residue, mold, and residue.
Wet a cleaning cloth with hot, soapy water.
Wipe the inside of the cavity until the surfaces are clean.
Step 4 Clean the dispenser drawer
Slide the fabric softener level indicator upward to access the area underneath it.
Use an brush and hot, soapy water to scrub mold, detergent residue, fabric softener residue, and residue from the drawer.
Scrub under the indicator and inside each compartment until the drawer is clean.
Step 5 Refit the dispenser drawer
Make sure the fabric softener level indicator is seated in the drawer.
Align the drawer with the grooves in the dispenser opening.
Slide the drawer all the way in until it sits fully home.
Step 6 Check the drum rubber
Open the washer door and inspect the drum rubber for debris, residue, and blockages.
Carefully check the folds of the rubber by sight and touch.
Remove any visible debris from the rubber.
Use an brush and hot, soapy water to scrub dirty areas of the rubber.
Step 7 Run a hot empty wash
Close the door and leave the drum empty.
Select a 90 °C wash program, the Drum Clean option, or the hottest wash available.
Start the cycle to flush residue from the washing machine.
Wait for the cycle to finish before washing clothes.
The dispenser drawer, drawer cavity, and drum rubber are clean, and the hot empty wash has flushed the machine for the next laundry load. Repeat this maintenance whenever the drawer collects residue or mold. Repair didn't go as planned? Ask our Answers community for help.
