Whirlpool WED87HED Control Panel Replacement prereq
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. Whirlpool WED87HED Control Panel Replacement prereq, Disconnect the control panel: step 1, image 1 of 2 Whirlpool WED87HED Control Panel Replacement prereq, Disconnect the control panel: step 1, image 2 of 2
      • Disconnect the control panel cable from the main board.
      Ask FixBot
    2. Whirlpool WED87HED Control Panel Replacement prereq: step 2, image 1 of 2 Whirlpool WED87HED Control Panel Replacement prereq: step 2, image 2 of 2
      • Disconnect the drum light connector.
      Ask FixBot
    3. Whirlpool WED87HED Control Panel Replacement prereq, Unfasten the control panel: step 3, image 1 of 2 Whirlpool WED87HED Control Panel Replacement prereq, Unfasten the control panel: step 3, image 2 of 2
      • Use a 1/4 inch nut driver to remove the two 16.3 mm‑long sheet metal screws located at each end of the control panel.
      Ask FixBot
    4. Whirlpool WED87HED Control Panel Replacement prereq, Remove the control panel: step 4, image 1 of 3 Whirlpool WED87HED Control Panel Replacement prereq, Remove the control panel: step 4, image 2 of 3 Whirlpool WED87HED Control Panel Replacement prereq, Remove the control panel: step 4, image 3 of 3
      • Lift the control panel up and tilt it away from the chassis to remove it.
      • Make sure to thread the cable through the hole in the chassis.
      • During reassembly, thread the cable through its proper hole before reinstalling the control panel.
      Ask FixBot
Bill Gilbert
40,590 Reputation
261 Guides authored
iFixit Member of iFixit
Staff
122 Members
72,401 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 14
All Time: 148
