Whirlpool Refrigerator - WRS588FIHB Control Board Replacement
  1. Whirlpool Refrigerator - WRS588FIHB Control Board Replacement, Safety precautions: step 1, image 1 of 1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. Whirlpool Refrigerator - WRS588FIHB Control Board Replacement, Unfasten the dispenser panels: step 2, image 1 of 2 Whirlpool Refrigerator - WRS588FIHB Control Board Replacement, Unfasten the dispenser panels: step 2, image 2 of 2
    • The dispenser panel screws are located under the dispenser as if you're looking up into the dispenser tube (where the ice cubes and water come out).
    • Remove the screw(s) securing the two dispenser panels.
  3. Whirlpool Refrigerator - WRS588FIHB Control Board Replacement, Remove the dispenser panels: step 3, image 1 of 3 Whirlpool Refrigerator - WRS588FIHB Control Board Replacement, Remove the dispenser panels: step 3, image 2 of 3 Whirlpool Refrigerator - WRS588FIHB Control Board Replacement, Remove the dispenser panels: step 3, image 3 of 3
    • Pull the dispenser panels straight down to separate them from the chassis.
    • Remove the dispenser panels.
  4. Whirlpool Refrigerator - WRS588FIHB Control Board Replacement, Unfasten the control board: step 4, image 1 of 1
    • Remove the screw(s) securing the control board.
  5. Whirlpool Refrigerator - WRS588FIHB Control Board Replacement: step 5, image 1 of 3 Whirlpool Refrigerator - WRS588FIHB Control Board Replacement: step 5, image 2 of 3 Whirlpool Refrigerator - WRS588FIHB Control Board Replacement: step 5, image 3 of 3
    • Tilt the bottom of the control board away from the chassis to release its clips.
    • Pull straight down to separate the control board enough to access its connectors.
  6. Whirlpool Refrigerator - WRS588FIHB Control Board Replacement, Disconnect the control board: step 6, image 1 of 3 Whirlpool Refrigerator - WRS588FIHB Control Board Replacement, Disconnect the control board: step 6, image 2 of 3 Whirlpool Refrigerator - WRS588FIHB Control Board Replacement, Disconnect the control board: step 6, image 3 of 3
    • Disconnect the connectors attached to the control board.
  7. Whirlpool Refrigerator - WRS588FIHB Control Board Replacement, Remove the control board: step 7, image 1 of 1
    • Remove the control board.
Matt Zieminski
38,264 Reputation
13 Guides authored
iFixit Member of iFixit
Staff
137 Members
17,520 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 7
