Wen 2307 Power Switch Replacement
    1. Wen 2307 Power Switch Replacement, Front Panel: step 1, image 1 of 1
      • Unscrew the locking sleeve.
      Ask FixBot
    2. Wen 2307 Power Switch Replacement: step 2, image 1 of 1
      • Remove the hanging clip.
      Ask FixBot
    3. Wen 2307 Power Switch Replacement: step 3, image 1 of 2 Wen 2307 Power Switch Replacement: step 3, image 2 of 2
      • Unscrew the six 8mm PH2 screws.
      Ask FixBot
    4. Wen 2307 Power Switch Replacement: step 4, image 1 of 1
      • While pressing the spindle lock button, unscrew the collet nut and remove it along with the brass collet.
      Ask FixBot
    5. Wen 2307 Power Switch Replacement: step 5, image 1 of 1
      • To remove the front panel, pry the device apart while holding the device with the other hand.
      • The front panel should come out easily.
      Ask FixBot
    1. Wen 2307 Power Switch Replacement, Power Switch: step 6, image 1 of 1
      • Firmly grasp and lift out power switch.
      Ask FixBot
    2. Wen 2307 Power Switch Replacement: step 7, image 1 of 1
      • Firmly grasp and disconnect cables.
      • Make sure to mark your cable positions so you do not reverse them when putting back together.
      Ask FixBot
2 other people completed this guide.
Joshua Bowery
570 Reputation
3 Guides authored
USF Tampa, Team 12-1, Eyestone Spring 2016 Member of USF Tampa, Team 12-1, Eyestone Spring 2016
USFT-EYESTONE-S16S12G1
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 97
All Time: 1,526
