Wen 2307 Motor Replacement
    1. Wen 2307 Motor Replacement, Front Panel: step 1, image 1 of 1
      • Unscrew the locking sleeve.
      Ask FixBot
    2. Wen 2307 Motor Replacement: step 2, image 1 of 1
      • Remove the hanging clip.
      Ask FixBot
    3. Wen 2307 Motor Replacement: step 3, image 1 of 2 Wen 2307 Motor Replacement: step 3, image 2 of 2
      • Unscrew the six 8mm PH2 screws.
      Ask FixBot
    4. Wen 2307 Motor Replacement: step 4, image 1 of 1
      • While pressing the spindle lock button, unscrew the collet nut and remove it along with the brass collet.
      Ask FixBot
    5. Wen 2307 Motor Replacement: step 5, image 1 of 1
      • To remove the front panel, pry the device apart while holding the device with the other hand.
      • The front panel should come out easily.
      Ask FixBot
    1. Wen 2307 Motor Replacement, Speed Adjustment Assembly: step 6, image 1 of 1
      • Remove the connected wiring from the circuit board.
      Ask FixBot
    2. Wen 2307 Motor Replacement: step 7, image 1 of 1
      • Remove the single 4mm screw retaining the circuit board.
      Ask FixBot
    3. Wen 2307 Motor Replacement: step 8, image 1 of 1
      • Gently pry the circuit board from the back piece.
      Ask FixBot
    1. Wen 2307 Motor Replacement, Motor: step 9, image 1 of 1
      • Gently pull motor assembly out of the panel.
      Ask FixBot
    2. Wen 2307 Motor Replacement: step 10, image 1 of 1
      • Motor separates into two pieces.
      Ask FixBot
Joshua Bowery
570 Reputation
3 Guides authored
USF Tampa, Team 12-1, Eyestone Spring 2016 Member of USF Tampa, Team 12-1, Eyestone Spring 2016
USFT-EYESTONE-S16S12G1
4 Members
42 Guides authored
1 Guide Comment
All very well and good, but it’s impossible to buy the motor parts to replace…
Closetslave 1 - Reply Share
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 41
All Time: 1,204
