Wen 2307 Fan Replacement
    1. Wen 2307 Fan Replacement, Front Panel: step 1, image 1 of 1
      • Unscrew the locking sleeve.
      Ask FixBot
    2. Wen 2307 Fan Replacement: step 2, image 1 of 1
      • Remove the hanging clip.
      Ask FixBot
    3. Wen 2307 Fan Replacement: step 3, image 1 of 2 Wen 2307 Fan Replacement: step 3, image 2 of 2
      • Unscrew the six 8mm PH2 screws.
      Ask FixBot
    4. Wen 2307 Fan Replacement: step 4, image 1 of 1
      • While pressing the spindle lock button, unscrew the collet nut and remove it along with the brass collet.
      Ask FixBot
    5. Wen 2307 Fan Replacement: step 5, image 1 of 1
      • To remove the front panel, pry the device apart while holding the device with the other hand.
      • The front panel should come out easily.
      Ask FixBot
    1. Wen 2307 Fan Replacement, Speed Adjustment Assembly: step 6, image 1 of 1
      • Remove the connected wiring from the circuit board.
      Ask FixBot
    2. Wen 2307 Fan Replacement: step 7, image 1 of 1
      • Remove the single 4mm screw retaining the circuit board.
      Ask FixBot
    3. Wen 2307 Fan Replacement: step 8, image 1 of 1
      • Gently pry the circuit board from the back piece.
      Ask FixBot
    1. Wen 2307 Fan Replacement, Motor: step 9, image 1 of 1
      • Gently pull motor assembly out of the panel.
      Ask FixBot
    2. Wen 2307 Fan Replacement: step 10, image 1 of 1
      • Motor separates into two pieces.
      Ask FixBot
    1. Wen 2307 Fan Replacement, Fan: step 11, image 1 of 1
      • The fan assembly is attached to the rotor beam, it can be disassembled to change the fan by simply pulling off the pieces.
      Ask FixBot
2 other people completed this guide.
Joshua Bowery
570 Reputation
3 Guides authored
USF Tampa, Team 12-1, Eyestone Spring 2016 Member of USF Tampa, Team 12-1, Eyestone Spring 2016
USFT-EYESTONE-S16S12G1
4 Members
72 Guides authored
1 Guide Comment
Donde puedo conseguir ese motor completo?
#silencio$ - Reply Share
Past 24 Hours: 2
Past 7 Days: 22
Past 30 Days: 88
All Time: 1,144
