Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement
  1. Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement, Stand: step 1, image 1 of 2 Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement, Stand: step 1, image 2 of 2
    • Unplug the AC power connection cable.
  2. Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement: step 2, image 1 of 3 Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement: step 2, image 2 of 3 Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement: step 2, image 3 of 3
    • Place your thumb and forefinger on the blood pressure (NIBP) hose connector. Squeeze the side tabs until the connector releases.
    • Always grasp the hose by the connector. Do not pull on the hose itself.
    • Pull the connector away from the connector port.
  3. Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement: step 3, image 1 of 3 Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement: step 3, image 2 of 3 Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement: step 3, image 3 of 3
    • Place your thumb and forefinger on the Pulse oximetry (SpO2 or combined SpO2/SpHb) cable connector. Squeeze the side tabs until the connector releases.
    • Always grasp the cable by the connector. Do not pull on the cable itself.
  4. Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement: step 4, image 1 of 2 Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement: step 4, image 2 of 2
    • Grasp the temperature probe and pull it up to remove it from the monitor.
  5. Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement: step 5, image 1 of 3 Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement: step 5, image 2 of 3 Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement: step 5, image 3 of 3
    • Remove the cover of the temperature module by pressing the tab and sliding the cover to the right.
  6. Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement: step 6, image 1 of 3 Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement: step 6, image 2 of 3 Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement: step 6, image 3 of 3
    • Depress the spring tab on the temperature probe cable connector and withdraw it from the probe port.
  7. Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement: step 7, image 1 of 1
    • Remove the flathead screw on the USB networking door.
    • Loosen the captive Phillips #2 screw securing the monitor to the stand.
  8. Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement: step 8, image 1 of 1
    • Holding the monitor securely, open the USB networking door.
    • You may have to lift the monitor slightly to allow the door to swing out from the stand mount.
  9. Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement: step 9, image 1 of 2 Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement: step 9, image 2 of 2
    • Detach any accessory USB cables from USB ports on the monitor.
  10. Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement: step 10, image 1 of 3 Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement: step 10, image 2 of 3 Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement: step 10, image 3 of 3
    • Slide the monitor off of the stand tray.
  11. Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement, Battery: step 11, image 1 of 3 Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement, Battery: step 11, image 2 of 3 Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement, Battery: step 11, image 3 of 3
    • Place the monitor upside down on a clean surface.
    • Insert a coin into the slot and push to open.
    • Choose a coin that fits comfortably into the slot.
    • Remove the battery cover.
  12. Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement: step 12, image 1 of 3 Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement: step 12, image 2 of 3 Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement: step 12, image 3 of 3
    • Use the plastic label to remove the battery from its recess.
kyle2
101 Reputation
1 Guide authored
Team Freedom Member of Team Freedom
Community
1 Member
3 Guides authored
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 33
All Time: 2,791
