Waterproof Bluetooth HEMA speaker Battery Replacement
    1. Waterproof Bluetooth HEMA speaker Battery Replacement, Battery: step 1, image 1 of 1
      • Turn the device upside down.
      Ask FixBot
    2. Waterproof Bluetooth HEMA speaker Battery Replacement: step 2, image 1 of 1
      • Pull off the rubber suction cup.
      Ask FixBot
    3. Waterproof Bluetooth HEMA speaker Battery Replacement: step 3, image 1 of 1
      • Unscrew the four 6mm round Phillips #000 head screws on the bottom of the product.
      Ask FixBot
    4. Waterproof Bluetooth HEMA speaker Battery Replacement: step 4, image 1 of 2 Waterproof Bluetooth HEMA speaker Battery Replacement: step 4, image 2 of 2
      • Remove the rear clamshell.
      • Separate the battery from the speaker by pulling gently. The foam adhesive will release.
      Ask FixBot
    5. Waterproof Bluetooth HEMA speaker Battery Replacement: step 5, image 1 of 1
      • Unscrew the four 4 mm round Phillips #000 screws that keep the circuit board in place.
      • Take out the circuit board.
      Ask FixBot
    6. Waterproof Bluetooth HEMA speaker Battery Replacement: step 6, image 1 of 1
      • Detach the battery by gently unsoldering the wires with a soldering iron. Also look at the colors of the wires,
      • Take note of the location the wires were attached and the negative and positive side.
      • Take a new 3,7V 400 mA Lithium battery and solder it to the circuit board where the old battery was attached.
      Ask FixBot
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 23
Past 30 Days: 105
All Time: 1,718
