Kindle 8 Water Damage repair
  1. Kindle 8 Water Damage repair, Disassemble the primary frame: step 1, image 1 of 2 Kindle 8 Water Damage repair, Disassemble the primary frame: step 1, image 2 of 2
    • Use a piece of plastic, like a credit or store card, to open up the case.
  2. Kindle 8 Water Damage repair, Detach the secondary frame: step 2, image 1 of 3 Kindle 8 Water Damage repair, Detach the secondary frame: step 2, image 2 of 3 Kindle 8 Water Damage repair, Detach the secondary frame: step 2, image 3 of 3
    • Lift the cover with a plastic card and carefully pull it off.
    • Tip: The glue is very strong, so I recommend helping things along with the plastic card.
    • If you remove the cover slowly and don't stick the plastic card in too far, you might be able to re-use the strip of glue.
  3. Kindle 8 Water Damage repair, Detach display and mainboard: step 3, image 1 of 2 Kindle 8 Water Damage repair, Detach display and mainboard: step 3, image 2 of 2
    • Loosen the seven 20mm T5 screws.
    • Then slide the display upwards.
  4. Kindle 8 Water Damage repair, Disconnect the battery: step 4, image 1 of 1
    • Now the battery can be disconnected and replaced, if necessary.
  5. Kindle 8 Water Damage repair, Detach the display cable: step 5, image 1 of 1
    • This Kindle has water damage which corroded the display cable.
    • I think changing the display is not possible because it is glued to the mainboard, possibly even soldered. I won't try replacing it because I only need to clean the display connector.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Lukas Wolf
121 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 18
Past 30 Days: 62
All Time: 884
