Up to 20% off select tools
Watch Battery Replacement
Views: 61K
View statistics:
Past 24 Hours:
24
Past 7 Days:
169
Past 30 Days:
813
All Time:
61,101
Comments: 9
2 comments on steps, 7 guide comments.
Go to guide comments
Completed: 10
10 people have marked this guide "completed." Will you be next?
Favorites: 5
5 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 seconds
Difficulty: Easy
Introduction
Go to step 1 ↓
I am going to show you how to replace your watch battery and show you how to preserve the life of your new watch battery.
    1. Watch Battery Replacement, Battery: step 1, image 1 of 2 Watch Battery Replacement, Battery: step 1, image 2 of 2
      • For this project you will need the watch you are replacing the battery on, the new battery and a mini flat head screwdriver.
      Ask FixBot
    2. Watch Battery Replacement: step 2, image 1 of 3 Watch Battery Replacement: step 2, image 2 of 3 Watch Battery Replacement: step 2, image 3 of 3
      • You will need to take the back of the watch off. To do this you will turn the watch over to the back side and look carefully for a small groove opening. This is where you will use the mini flat head screwdriver. Insert the flat head screwdriver into the groove and pop the back off of the watch.
      Ask FixBot
    3. Watch Battery Replacement: step 3, image 1 of 2 Watch Battery Replacement: step 3, image 2 of 2
      • Take the white plastic ring out of the watch. You can use the mini flat head screwdriver or your finger to pull it out.
      Ask FixBot
    4. Watch Battery Replacement: step 4, image 1 of 3 Watch Battery Replacement: step 4, image 2 of 3 Watch Battery Replacement: step 4, image 3 of 3
      • Take the old battery out of the watch. You can use the mini flat head screwdriver to do this.
      Ask FixBot
    5. Watch Battery Replacement: step 5, image 1 of 1
      • Put the new battery in watch. Use your fingers to insert the new battery.
      Ask FixBot
    6. Watch Battery Replacement: step 6, image 1 of 1
      • Use your fingers to insert the plastic white ring back into the watch.
      Ask FixBot
    7. Watch Battery Replacement: step 7, image 1 of 1
      • Put the back of the watch on using your fingers. Press down so that you hear a snap to ensure the back is on properly.
      Ask FixBot
    8. Watch Battery Replacement: step 8, image 1 of 1
      • You are all done and can now set the time on your watch.
      Ask FixBot
    9. Watch Battery Replacement: step 9, image 1 of 2 Watch Battery Replacement: step 9, image 2 of 2
      • When you are not using the watch, pull the pin out to stop the watch from running
      Ask FixBot
    10. Watch Battery Replacement: step 10, image 1 of 1
      • When the pin is pulled out, the battery is not being used. Only push the pin in and set the time when you are using the watch. This will preserve the life of your new battery.
      Ask FixBot
10 other people completed this guide.
Author
with
TIMONTE HUNTER
418 Reputation
1 Guide authored
7 Guide Comments
First time I have done this and I have somehow lost the white plastic! Is this essential?
barbaramcraig - Reply Share
Yes. I can’t get the plastic spacer back in right. I guess that is why I can’t get the back.
jybentneedle48 - Reply Share
I'm trying to figure out the type of watch that is can anyone help me that? This is the only place I can find an image of it. I recently purchased it private sale and they couldn't remember.
karmstrong20112012 - Reply Share
Googling the model number on the back, LDC74709W, leads me to believe it’s an unbranded watch that was sold at Walmart in the past.
Austin Blakely - Reply Share
What is the battery number
David Corley - Reply Share
Past 24 Hours: 24
Past 7 Days: 169
Past 30 Days: 813
All Time: 61,101
