Shop the Holiday Gift Guide
Washing Machine Water Supply Shutoff
Views: 1.9K
View statistics:
Past 24 Hours:
18
Past 7 Days:
164
Past 30 Days:
579
All Time:
1,851
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Moderate
Video Guide
This guide was transcribed from a YouTube video.
Introduction
Go to step 1 ↓
Use this guide to isolate the water supply to a washing machine before uninstalling it, investigating a leak, or working on the inlet hose. Most washing machines have one cold power supply water feed hose, but some installations also have a hot water feed hose. This guide covers machines next to a sink, machines with a tap behind them, and machines that must be isolated at the power supply stopcock.
      • Turn off the washing machine before you work around the water supply.
      • Unplug the washing machine if the plug and floor are dry enough to reach safely.
      • Don't touch a plug, outlet, or switch with wet hands or while standing in water.
      • Most washing machines have one cold power supply water feed hose, but some installations may also have a hot water feed hose.
      • If the machine has both hot and cold feed hoses, shut off both supplies.
      Ask FixBot
      • If the washing machine is next to a sink, clear the space under the sink so you can see the pipework.
      • Identify the washing machine drainage hose and the power supply inlet water feed hose.
      • Look for the cold water feed with a blue tap fitted to it.
      • The drainage hose carries used water away from the washing machine and isn't the supply hose.
      Ask FixBot
      • Turn the blue tap 90 degrees to shut off the cold water supply to the washing machine.
      • The tap should only turn one way from the open position.
      • Do not force a stiff tap, as old taps that haven't moved for a long time may be hard to turn.
      Ask FixBot
      • If the washing machine isn't next to a sink, pull the washing machine out far enough to access the back.
      • Move the washing machine slowly so you don't stretch, kink, or pull the hoses.
      • Look behind the washing machine for the same type of water supply tap on the inlet hose.
      • Turn the rear tap 90 degrees to shut off the water supply.
      Ask FixBot
      • Use the power supply stopcock if you can't find the washing machine water feed hose or its local shutoff tap.
      • Be aware that closing the power supply stopcock may turn off the water to the whole property.
      • Locate the power supply stopcock before a plumbing emergency so you can shut off the water quickly.
      • Turn the power supply stopcock clockwise to turn the water off.
      Ask FixBot
      • Turn the under sink or rear washing machine tap 90 degrees back to restore the water feed.
      • Open the power supply stopcock fully if you used it to shut off the water.
      • Check around the hose connections for leaks after the water supply is restored.
      Ask FixBot
      • After opening the power supply stopcock fully, turn it back slightly.
      • This helps stop the stopcock from jamming over time if it isn't used often.
      Ask FixBot
The washing machine water supply is now isolated or restored. Repair didn't go as planned? Ask our Answers community for help.
Author
with
eCuration
478,744 Reputation
396 Guides authored
0 Guide Comments
Past 24 Hours: 18
Past 7 Days: 164
Past 30 Days: 579
All Time: 1,851
