Up to 20% off select tools
Washing Machine Mercury Recovery Procedure
View statistics:
Past 24 Hours:
2
Past 7 Days:
19
Past 30 Days:
49
All Time:
223
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Easy
In Progress
This guide is a work in progress. Reload periodically to see the latest changes!
Introduction
The Mercury Recovery procedure ensures the safe extraction of mercury switches from appliances while working in the Market Delivery Operation (MDO) facilities.
Mercury switch found in washing machines may be located
  • Between the washer tub and the cover for the tub area of the washer.
  • Back of washing machine
Technicians should carefully inspect these areas to identify any mercury switches. If the technician finds a tab or button along the rim of the lid, this is an indication of a mechanical switch which results in no mercury switch.
Regardless of if mercury switches were found or not, the technician should place a completion sticker over the “May Contain Mercury Switches NEEDS INSPECTION” sticker to signify that the unit was inspected.
IMPORTANT: If Mercury is released during recovery, the technician should contact the MDOM and 3E for cleanup and rope off the area with cones (and caution tape, if available).
To recovery mercury switches from washing machines, complete the following steps:
Featured Document
Finish Line
Tanisha Meredith
3,282 Reputation
28 Guides authored
The Home Depot Member of The Home Depot
Community
29,684 Members
864 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 49
All Time: 223
