Warm Audio EQP-WA Tube Replacement
  1. Warm Audio EQP-WA Tube Replacement, Unscrew the cover: step 1, image 1 of 3 Warm Audio EQP-WA Tube Replacement, Unscrew the cover: step 1, image 2 of 3 Warm Audio EQP-WA Tube Replacement, Unscrew the cover: step 1, image 3 of 3
    • Unplug the unit from the mains power before opening it.
    • Remove the screws at the top, sides and back of the unit with a standard phillips screwdriver.
  2. Warm Audio EQP-WA Tube Replacement, Remove the lid: step 2, image 1 of 2 Warm Audio EQP-WA Tube Replacement, Remove the lid: step 2, image 2 of 2
    • Remove the lid and locate the tubes.
  3. Warm Audio EQP-WA Tube Replacement, Remove the shields: step 3, image 1 of 1
    • The tubes are covered by a metal shield. To remove this shield, push down a bit and rotate, then pull up the shield.
  4. Warm Audio EQP-WA Tube Replacement, Replace the tube: step 4, image 1 of 2 Warm Audio EQP-WA Tube Replacement, Replace the tube: step 4, image 2 of 2
    • Pull out the tube that needs changing. Only the glass part comes out.
    • It will probably need some wiggling as you pull.
    • When inserting the new tube, pay attention to how it lines up in the socket, make sure it's completely aligned before pushing, because it will need a good push down and if not aligned correctly, this can bend the tube legs.
palako
962 Reputation
7 Guides authored
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 32
All Time: 2,212
