Waring 51BL29 Switch Replacement
    1. Waring 51BL29 Switch Replacement, Bottom Panel: step 1, image 1 of 2 Waring 51BL29 Switch Replacement, Bottom Panel: step 1, image 2 of 2
      • Turn the blender on its side so the bottom panel is facing you.
      • Unscrew the 22mm Phillips #1 screw on the indent of the panel.
      • Unscrew the 3 screws in the rubber holes.
      Ask FixBot
    2. Waring 51BL29 Switch Replacement: step 2, image 1 of 1
      • Remove the bottom panel.
      Ask FixBot
    1. Waring 51BL29 Switch Replacement, Drive Coupling: step 3, image 1 of 1
      • Place the screwdriver in the head of the middle flat-head screw.
      Ask FixBot
    2. Waring 51BL29 Switch Replacement: step 4, image 1 of 1
      • Unscrew this screw while holding the coupling with your other hand and not allowing it to rotate.
      • This screw may be reverse-threaded.
      Ask FixBot
    3. Waring 51BL29 Switch Replacement: step 5, image 1 of 1
      • Once the coupling mechanism has been loosened all the way, gently pull it off the top of the blender.
      Ask FixBot
    1. Waring 51BL29 Switch Replacement, Motor: step 6, image 1 of 2 Waring 51BL29 Switch Replacement, Motor: step 6, image 2 of 2
      • Unscrew the four nuts in the bottom of the motor cavity.
      • Wiggle the motor until it is free and you can remove it.
      Ask FixBot
    2. Waring 51BL29 Switch Replacement: step 7, image 1 of 1
      • Once motor is pulled out, unscrew the 8 mm screw for the green wire from the base of the blender.
      Ask FixBot
    3. Waring 51BL29 Switch Replacement: step 8, image 1 of 3 Waring 51BL29 Switch Replacement: step 8, image 2 of 3 Waring 51BL29 Switch Replacement: step 8, image 3 of 3
      • Unscrew each white wire cap in order to free the motor from the power cord.
      • Once wire caps are removed, separate wires carefully.
      Ask FixBot
    1. Waring 51BL29 Switch Replacement, Switch: step 9, image 1 of 1
      • Once you have the motor and switch by themselves it should look like this.
      Ask FixBot
    2. Waring 51BL29 Switch Replacement: step 10, image 1 of 2 Waring 51BL29 Switch Replacement: step 10, image 2 of 2
      • Separate the zip-tie holding the wires to the motor.
      Ask FixBot
    3. Waring 51BL29 Switch Replacement: step 11, image 1 of 1
      • Now the switch is separated from the motor and blender frame.
      Ask FixBot
Dean Becker
485 Reputation
4 Guides authored
Cal Poly, Team S15-G4, Banghart Spring 2017 Member of Cal Poly, Team S15-G4, Banghart Spring 2017
CPSU-BANGHART-S17S15G4
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 21
Past 30 Days: 101
All Time: 1,285
