Waring 51BL29 Bottom Panel Replacement
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. Waring 51BL29 Bottom Panel Replacement, Bottom Panel: step 1, image 1 of 2 Waring 51BL29 Bottom Panel Replacement, Bottom Panel: step 1, image 2 of 2
      • Turn the blender on its side so the bottom panel is facing you.
      • Unscrew the 22mm Phillips #1 screw on the indent of the panel.
      • Unscrew the 3 screws in the rubber holes.
      Ask FixBot
    2. Waring 51BL29 Bottom Panel Replacement: step 2, image 1 of 1
      • Remove the bottom panel.
      Ask FixBot
Dean Becker
485 Reputation
4 Guides authored
Cal Poly, Team S15-G4, Banghart Spring 2017 Member of Cal Poly, Team S15-G4, Banghart Spring 2017
CPSU-BANGHART-S17S15G4
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 10
All Time: 175
