Introduction
Toilet paper dispensers are very useful house item to use when using the bathroom. However, if you see your dispenser becoming loose, wobbly, or broken, it can be frustrating and that means the drywall anchors must be replaced. This is commonly caused by the commonly pushing and pulling of the holders on the sides which interferes with the anchors, therefore, causing it to become loose.
With just the use of screwdrivers, this step-by-step guide briefly follows the process of replacing dry wall anchors on a toilet paper dispenser to make it more strong and secure.
First, remove the spring from the dispenser so we can remove the loose part.
This can be done by pressing the spring back towards the other side. Here, the anchors on the left holder is loose so that's what's going to be replaced.
