Kitchen Gourmet Waffle Maker Release Latch Spring Replacement
  1. Kitchen Gourmet Waffle Maker Release Latch Spring Replacement, Release Latch Spring: step 1, image 1 of 1
    • Unplug the waffle maker.
  2. Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: step 2, image 1 of 3 Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: step 2, image 2 of 3 Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: step 2, image 3 of 3
    • Open the waffle maker.
    • Make sure the waffle maker's surface is not hot.
  3. Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: step 3, image 1 of 3 Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: step 3, image 2 of 3 Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: step 3, image 3 of 3
    • Spray the interior of the waffle maker with cleaning solution.
    • Clean and wipe down the surface.
  4. Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: step 4, image 1 of 2 Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: step 4, image 2 of 2
    • Use a Phillips #1 screwdriver to remove the four screws that secure the plastic handle cover.
    • Spin in counterclockwise direction to loosen.
  5. Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: step 5, image 1 of 3 Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: step 5, image 2 of 3 Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: step 5, image 3 of 3
    • Carefully pull back the plastic cover, and gently remove the release latch.
  6. Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: step 6, image 1 of 2 Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: step 6, image 2 of 2
    • Remove the spring from the latch.
  7. Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: step 7, image 1 of 3 Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: step 7, image 2 of 3 Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: step 7, image 3 of 3
    • Carefully replace with the new spring.
    • Pliers are recommended but removal with hands is fine.
    • Be careful not to bend the spring when pushing into the plastic handle.
  8. Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: step 8, image 1 of 3 Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: step 8, image 2 of 3 Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: step 8, image 3 of 3
    • Orient the release latch in the correct direction, and line up the spring.
  9. Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: step 9, image 1 of 3 Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: step 9, image 2 of 3 Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: step 9, image 3 of 3
    • Hold the latch in place.
    • Line up the screw holes on the plastic cover to the waffle maker lid.
  10. Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: step 10, image 1 of 2 Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: step 10, image 2 of 2
    • Screw in all four screws tightly.
    • Spin in clockwise direction to tighten.
    • Screw in opposing screws first to keep them in place.
Fatima Ruiz Ruiz
193 Reputation
1 Guide authored
UC Davis, Team 3-4, Andersen Winter 2024 Member of UC Davis, Team 3-4, Andersen Winter 2024
UCD-ANDERSEN-W24S3G4
3 Members
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 29
All Time: 440
