WMF HA0064 hand mixer - replacement of the thermal fuse 115°C (AUPO P2-3A-F)
  1. WMF HA0064 hand mixer - replacement of the thermal fuse 115°C (AUPO P2-3A-F), Opening the case: step 1, image 1 of 2 WMF HA0064 hand mixer - replacement of the thermal fuse 115°C (AUPO P2-3A-F), Opening the case: step 1, image 2 of 2
    • There are three hurdles to be overcome to open the case:
    • 1. Remove the screw covers marked with a red arrow in the 1st picture. These are only plugged in, but extremely difficult to grasp. With luck and feeling you can do this with the Jimmy, alternatively with a kitchen knife.
    • In desperation, unfold a paper clip, moderately heat one end in the flame of a lighter or candle, insert into the plastic, wait for it to cool, and use it to pull the plastic out.
    • Whichever variant you choose, afterwards the case is usually at least scratched.
  2. WMF HA0064 hand mixer - replacement of the thermal fuse 115°C (AUPO P2-3A-F), Remove the triangle screws: step 2, image 1 of 1
    • 2. Unscrew the triangular screws on the back (red frame) and remove the back cover.
  3. WMF HA0064 hand mixer - replacement of the thermal fuse 115°C (AUPO P2-3A-F), Remove the Metal Ring: step 3, image 1 of 1
    • 3. Peel off the metal ring. For me it went down well with a moderate pull without much turning. According to the Internet, this step can also cause despair.
    • As you can see in the picture, the nose (red frame) doesn't necessarily make turning easier.
    • If an even pull doesn't help, the combination of a slotted screwdriver in the groove and a hammer in the appropriate direction has helped for some.
  4. WMF HA0064 hand mixer - replacement of the thermal fuse 115°C (AUPO P2-3A-F), Loosening the Phillips screws: step 4, image 1 of 2 WMF HA0064 hand mixer - replacement of the thermal fuse 115°C (AUPO P2-3A-F), Loosening the Phillips screws: step 4, image 2 of 2
    • After we have mastered the 3 previous steps, the matter is now relatively simple: Loosen all 4 exposed screws.
    • The inner workings are revealed.
  5. WMF HA0064 hand mixer - replacement of the thermal fuse 115°C (AUPO P2-3A-F), Expose thermal fuse: step 5, image 1 of 3 WMF HA0064 hand mixer - replacement of the thermal fuse 115°C (AUPO P2-3A-F), Expose thermal fuse: step 5, image 2 of 3 WMF HA0064 hand mixer - replacement of the thermal fuse 115°C (AUPO P2-3A-F), Expose thermal fuse: step 5, image 3 of 3
    • Carefully cut through the yellow adhesive tape (on the transformer?) with a knife or scissors etc. and fold outwards. The white component (red frame in Figure 1) is the target of the search.
    • Take the thermal fuse out from under the cables and expose the soldered ends (green frames in Figure 2).
    • To expose the soldering point at the top in the picture, the black shrink tubing must be slit open (with a knife, scalpel, etc.)
    • Be careful not to damage the cables in the shrink tubing (blue frame)!
  6. WMF HA0064 hand mixer - replacement of the thermal fuse 115°C (AUPO P2-3A-F), Remove old thermal fuse: step 6, image 1 of 3 WMF HA0064 hand mixer - replacement of the thermal fuse 115°C (AUPO P2-3A-F), Remove old thermal fuse: step 6, image 2 of 3 WMF HA0064 hand mixer - replacement of the thermal fuse 115°C (AUPO P2-3A-F), Remove old thermal fuse: step 6, image 3 of 3
    • I - as I said, an electronics layman - followed the motto here: break as little as possible and leave everything as you found it. Specifically, I unwound the soldered copper wires from the wires of the fuse using sturdy tweezers and fingernails (red frames).
    • People who have more knowledge or less patience may know better whether you can simply unclip the wires with the wire cutters. I was more comfortable with unwinding.
  7. WMF HA0064 hand mixer - replacement of the thermal fuse 115°C (AUPO P2-3A-F), Wire in a new fuse: step 7, image 1 of 3 WMF HA0064 hand mixer - replacement of the thermal fuse 115°C (AUPO P2-3A-F), Wire in a new fuse: step 7, image 2 of 3 WMF HA0064 hand mixer - replacement of the thermal fuse 115°C (AUPO P2-3A-F), Wire in a new fuse: step 7, image 3 of 3
    • Pre-bend the new fuse (picture 1), pull the rubber hoses back on (they'll be good for something, even if there's only adhesive tape around them. ;-) )
    • Reconstruction: Wrap the copper wires to the fuse as it was on the old one (red frames).
  8. WMF HA0064 hand mixer - replacement of the thermal fuse 115°C (AUPO P2-3A-F), ... and soldering the fuse: step 8, image 1 of 2 WMF HA0064 hand mixer - replacement of the thermal fuse 115°C (AUPO P2-3A-F), ... and soldering the fuse: step 8, image 2 of 2
    • After soldering, it can look like mine (inexperienced first-time solderer): not nice, but useful.
    • In the absence of shrink tubing, I simply put the upper end in the picture back into the old shrink tubing. So far it works. ;-)
  9. WMF HA0064 hand mixer - replacement of the thermal fuse 115°C (AUPO P2-3A-F), Stow the fuse and secure with tape: step 9, image 1 of 2 WMF HA0064 hand mixer - replacement of the thermal fuse 115°C (AUPO P2-3A-F), Stow the fuse and secure with tape: step 9, image 2 of 2
    • After repositioning the fuse, I resealed the old tape with commercial electrical tape in case it served a purpose.
  10. WMF HA0064 hand mixer - replacement of the thermal fuse 115°C (AUPO P2-3A-F), Assembly: step 10, image 1 of 1
    • The electronic repair is now complete. Now it remains to put the case back together. To do this, reverse steps 1-4.
    • Another photo of the screws if you are interested in replacement or exchange in advance.
Have fun with your intact hand mixer/hand mixer
2 other people completed this guide.
Special thanks to these translators:
de en
100%
oldturkey03 is helping us fix the world! Want to contribute?
Start translating ›
Hauke
241 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 81
All Time: 1,431
