Introduction
Recently my beloved hand mixer started to stink after 5 years of trying to knead a lot of pizza dough at once. As an electronics layman I thought it won't be that bad,. So I gave the hand mixer a well-deserved rest, expecting that after a few minutes of cooling everything would be fine again. But unfortunately I had to realize that my device not only wanted a break, but had canceled without notice. I can't let that happen, I thought, and went to the internet to look for a solution.
In fact, it turned out that this type of demise was not the exception but the rule for this model. My device with 5 years of (intense) use was damn late with the demise. Most devices probably didn't last more than a few uses or weeks.
Anyway, someone in a review knew the solution I had to try right away. And since these repair instructions cannot be found here yet, I would like to share them with you.
PS: You can think what you want about this model and its "speed levels" from fast to incredibly fast. My suspicion why our “Föhn” (so named because of the background noise and the exhaust air) lasted so long is that it was used a lot, but mainly for batter or pancake batter or similar. Firmer batter is probably only tolerable for a short time .
There are three hurdles to be overcome to open the case:
1. Remove the screw covers marked with a red arrow in the 1st picture. These are only plugged in, but extremely difficult to grasp. With luck and feeling you can do this with the Jimmy, alternatively with a kitchen knife.
In desperation, unfold a paper clip, moderately heat one end in the flame of a lighter or candle, insert into the plastic, wait for it to cool, and use it to pull the plastic out.
Whichever variant you choose, afterwards the case is usually at least scratched.
2. Unscrew the triangular screws on the back (red frame) and remove the back cover.
3. Peel off the metal ring. For me it went down well with a moderate pull without much turning. According to the Internet, this step can also cause despair.
As you can see in the picture, the nose (red frame) doesn't necessarily make turning easier.
If an even pull doesn't help, the combination of a slotted screwdriver in the groove and a hammer in the appropriate direction has helped for some.
After we have mastered the 3 previous steps, the matter is now relatively simple: Loosen all 4 exposed screws.
The inner workings are revealed.
Carefully cut through the yellow adhesive tape (on the transformer?) with a knife or scissors etc. and fold outwards. The white component (red frame in Figure 1) is the target of the search.
Take the thermal fuse out from under the cables and expose the soldered ends (green frames in Figure 2).
To expose the soldering point at the top in the picture, the black shrink tubing must be slit open (with a knife, scalpel, etc.)
Be careful not to damage the cables in the shrink tubing (blue frame)!
I - as I said, an electronics layman - followed the motto here: break as little as possible and leave everything as you found it. Specifically, I unwound the soldered copper wires from the wires of the fuse using sturdy tweezers and fingernails (red frames).
People who have more knowledge or less patience may know better whether you can simply unclip the wires with the wire cutters. I was more comfortable with unwinding.
Pre-bend the new fuse (picture 1), pull the rubber hoses back on (they'll be good for something, even if there's only adhesive tape around them. ;-) )
Reconstruction: Wrap the copper wires to the fuse as it was on the old one (red frames).
After soldering, it can look like mine (inexperienced first-time solderer): not nice, but useful.
In the absence of shrink tubing, I simply put the upper end in the picture back into the old shrink tubing. So far it works. ;-)
After repositioning the fuse, I resealed the old tape with commercial electrical tape in case it served a purpose.
The electronic repair is now complete. Now it remains to put the case back together. To do this, reverse steps 1-4.
Another photo of the screws if you are interested in replacement or exchange in advance.
Have fun with your intact hand mixer/hand mixer
2 other people completed this guide.
Special thanks to these translators:
100%
oldturkey03 is helping us fix the world! Want to contribute?
Start translating ›
