Replace WLAN / Bluetooth chipset
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
    1. Replace WLAN / Bluetooth chipset, Battery: step 1, image 1 of 3 Replace WLAN / Bluetooth chipset, Battery: step 1, image 2 of 3 Replace WLAN / Bluetooth chipset, Battery: step 1, image 3 of 3
      • Open the latch on the right side that secures the battery in place.
      • Open the latch on the left side that secures the battery in place.
      • Now remove the battery.
      Ask FixBot
    1. Replace WLAN / Bluetooth chipset, Main access cover: step 2, image 1 of 3 Replace WLAN / Bluetooth chipset, Main access cover: step 2, image 2 of 3 Replace WLAN / Bluetooth chipset, Main access cover: step 2, image 3 of 3
      • Using a Philips-head screwdriver remove highlighted screws.
      • Look at the marking to see how to remove the access cover.
      • Remove the access cover as shown by the marker.
      Ask FixBot
    2. Replace WLAN / Bluetooth chipset: step 3, image 1 of 1
      • You now have access to all components of this laptop.
      Ask FixBot
    1. Replace WLAN / Bluetooth chipset, WLAN/Bluetooth Chipset: step 4, image 1 of 3 Replace WLAN / Bluetooth chipset, WLAN/Bluetooth Chipset: step 4, image 2 of 3 Replace WLAN / Bluetooth chipset, WLAN/Bluetooth Chipset: step 4, image 3 of 3
      • Here is the chipset WLAN / Bluetooth.
      • Carefully loosen the antenna plugs MAIN and AUX.
      • Loosen the fixing screw with the Philips screwdriver.
      Ask FixBot
    2. Replace WLAN / Bluetooth chipset: step 5, image 1 of 2 Replace WLAN / Bluetooth chipset: step 5, image 2 of 2
      • Lift the chipset a little and pull it out to the mSATA connector.
      Ask FixBot
To assemble the device again, proceed in reverse order.
Special thanks to these translators:
de en
100%
irlanda is helping us fix the world! Want to contribute?
Start translating ›
Felice Suglia
33,634 Reputation
283 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 7
All Time: 184
