Shop the Holiday Gift Guide
WLAN Card Disconnect
View statistics:
Past 24 Hours:
0
Past 7 Days:
5
Past 30 Days:
11
All Time:
146
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Introduction
Go to step 1 ↓
Use this guide to disconnect the WLAN card wires in your Dell Latitude 7490.
Tools
    1. WLAN Card Disconnect, Prepare your laptop for disassembly: step 1, image 1 of 2 WLAN Card Disconnect, Prepare your laptop for disassembly: step 1, image 2 of 2
      • Allow your laptop's battery to drain below 25% before starting this repair—a charged battery may catch fire if damaged.
      • Unplug all cables and fully shut down your laptop.
      Ask FixBot
    1. WLAN Card Disconnect, Flip your laptop over: step 2, image 1 of 1
      • Flip your laptop over so the rubber feet strips are facing up.
      Ask FixBot
    2. WLAN Card Disconnect, Loosen the captive screws: step 3, image 1 of 2 WLAN Card Disconnect, Loosen the captive screws: step 3, image 2 of 2
      • Use a Phillips screwdriver to fully loosen the eight captive screws securing the back cover.
      Ask FixBot
    3. WLAN Card Disconnect, Insert an opening pick: step 4, image 1 of 3 WLAN Card Disconnect, Insert an opening pick: step 4, image 2 of 3 WLAN Card Disconnect, Insert an opening pick: step 4, image 3 of 3
      • Plastic clips secure the back cover to the frame. You'll hear and feel them release as you work.
      • Insert the long side of an opening pick between the top right corner of the back cover and frame.
      • Pry the back cover up to release the clips securing the top right corner.
      Ask FixBot
    4. WLAN Card Disconnect, Release the clips: step 5, image 1 of 3 WLAN Card Disconnect, Release the clips: step 5, image 2 of 3 WLAN Card Disconnect, Release the clips: step 5, image 3 of 3
      • Slide the opening pick down the right edge and around the bottom right corner to release the clips.
      Ask FixBot
    5. WLAN Card Disconnect: step 6, image 1 of 3 WLAN Card Disconnect: step 6, image 2 of 3 WLAN Card Disconnect: step 6, image 3 of 3
      • Slide the opening pick along the front edge and up to the top left corner to release the remaining clips securing the back cover.
      Ask FixBot
    6. WLAN Card Disconnect, Remove the back cover: step 7, image 1 of 3 WLAN Card Disconnect, Remove the back cover: step 7, image 2 of 3 WLAN Card Disconnect, Remove the back cover: step 7, image 3 of 3
      • Remove the back cover.
      • During reassembly, lay the back cover on the frame and press down firmly around the perimeter to engage all the clips.
      Ask FixBot
    1. WLAN Card Disconnect, Disconnect the battery: step 8, image 1 of 2 WLAN Card Disconnect, Disconnect the battery: step 8, image 2 of 2
      • Grip the plastic tab on the battery connector and pull straight up to disconnect it.
      • During reassembly, align this connector over its socket and press down until it clicks into place. If it doesn't connect, re‑align it and try again.
      Ask FixBot
    1. WLAN Card Disconnect, Unfasten the WLAN card: step 9, image 1 of 3 WLAN Card Disconnect, Unfasten the WLAN card: step 9, image 2 of 3 WLAN Card Disconnect, Unfasten the WLAN card: step 9, image 3 of 3
      Tool used on this step:
      Buy
      • Use a Phillips screwdriver to remove the 3.5 mm‑long screw securing the WLAN card and its bracket.
      • Use tweezers or your fingers to remove the WLAN card bracket.
      Ask FixBot
    2. WLAN Card Disconnect, Disconnect the WLAN card: step 10, image 1 of 3 WLAN Card Disconnect, Disconnect the WLAN card: step 10, image 2 of 3 WLAN Card Disconnect, Disconnect the WLAN card: step 10, image 3 of 3
      • Insert an arm of your angled tweezers under the metal neck of one the WLAN card's coaxial connectors.
      • Gently lift as close to the head as possible to disconnect the cable.
      • Repeat the process for the second antenna cable.
      • To reconnect coaxial connectors, hold each one in place over its socket and press down with the flat end of your spudger. The connector will snap into place.
      • If your device has an LTE (WWAN) card, follow the same procedure to remove it. The WWAN card is in a different location on the motherboard than the WLAN card shown.
      Ask FixBot
Author
with
Spencer Day
210,422 Reputation
1,265 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,954 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 11
All Time: 146
