Vulcan Venture II VNB14002IE I/O Board Replacement
  1. Vulcan Venture II VNB14002IE I/O Board Replacement, Back Panel: step 1, image 1 of 1
    • Use a J00 screwdriver to unscrew the 10 back-plate screws.
  2. Vulcan Venture II VNB14002IE I/O Board Replacement: step 2, image 1 of 1
    • Gently separate the back panel from the laptop.
  3. Vulcan Venture II VNB14002IE I/O Board Replacement, I/O Board: step 3, image 1 of 1
    • Locate the IO board on the back panel.
  4. Vulcan Venture II VNB14002IE I/O Board Replacement: step 4, image 1 of 2 Vulcan Venture II VNB14002IE I/O Board Replacement: step 4, image 2 of 2
    • Locate the ribbon connector on the IO board, and lift the black bar closest the the ribbon.
    • Pull the ribbon cable away from the connector, releasing it.
  5. Vulcan Venture II VNB14002IE I/O Board Replacement: step 5, image 1 of 2 Vulcan Venture II VNB14002IE I/O Board Replacement: step 5, image 2 of 2
    • Locate the screws on the IO panel, and use the J00+ bit to unscrew them.
  6. Vulcan Venture II VNB14002IE I/O Board Replacement: step 6, image 1 of 1
    • The IO Board is now safe to remove from the computer.
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 3
All Time: 508
