Introduction
These instructions are used to replace the battery of the device if it has lost capacity due to aging and the running time of the vacuum cleaner robot is severely limited.
Turn the robot over and place it on a suitable, soft surface. Make sure that the robot does not lie directly on the dome.
Use either two soft wooden slats or a small and sturdy cardboard box.
Now pry open the battery cover with a suitable tool (plectrum or plastic opening tool). Make sure that there are two latches on the opposite side of the screws. The cover must therefore be lifted from the screw-on side.
Removing the battery is a bit difficult. One possibility is that you use the plastic opening tool to remove the foam tape on the left and right side of the battery.
Then you can use both hands to lift the battery by the "ears" of the tape.
Disconnect the 4-pin plug of the battery by first pressing the latch and then pulling out the plug.
Now the replacement battery can be connected!
Work the steps in reverse order to reassemble your device.
8 other people completed this guide.
Special thanks to these translators:
100%
oldturkey03 is helping us fix the world! Want to contribute?
Start translating ›
6 Comments
Bin begeistert! Vielen DANK!! Ich hatte dieselben Fehler, jetzt laufen sowohl Fernbedienung als auch das Bedienfeld auf dem Display.
Hallo,
mein Sauger läßt sich nicht wie in Schritt 1 beschrieben komplett ausschalten. Kann ich den Akku trotzdem wechseln?
Hallo, klappt das so auch beim vr300? Ich habe gehört dort muss der Akku wieder angelernt werden?
Eigendlich logisch, dennoch gutes Manual. Gibt es noch einen „Hotkey“ damit der Robot auch weiss, das es einen neuen Accu gibt? Die SW Einstellung „Neuer Accu“ verursacht einen unnötigen Ladungsvorgang….
