Volume Control Potentiometer Cleaning
  1. Volume Control Potentiometer Cleaning, Unplug the receiver: step 1, image 1 of 1
    • In order to ensure there is no residual power, unplug the receiver for 48-72 hours. This will kill off most of it and make service safer.
    • Before working on the unit, disconnect the unit from the wall. Hold the power button in for 60 seconds to drain the capacitors.
  2. Volume Control Potentiometer Cleaning, Remove the bottom faceplate screws: step 2, image 1 of 2 Volume Control Potentiometer Cleaning, Remove the bottom faceplate screws: step 2, image 2 of 2
    • If present, remove this screw. This was not in my unit, but may be in yours.
    • Remove the two screws holding the faceplate on the receiver. Sort these individually as they are different.
  3. Volume Control Potentiometer Cleaning, Remove the side panel screws: step 3, image 1 of 3 Volume Control Potentiometer Cleaning, Remove the side panel screws: step 3, image 2 of 3 Volume Control Potentiometer Cleaning, Remove the side panel screws: step 3, image 3 of 3
    • Remove the 2 screws from the left side of the receiver. They are both the same length.
    • Remove the 1 screw on the right side of the receiver. While it appears to be the same, sort it separately.
  4. Volume Control Potentiometer Cleaning, Remove the back screws: step 4, image 1 of 3 Volume Control Potentiometer Cleaning, Remove the back screws: step 4, image 2 of 3 Volume Control Potentiometer Cleaning, Remove the back screws: step 4, image 3 of 3
    • Exercise extreme caution with the receiver at this point! You will not be protected from socks if you touch a charged component!
    • Remove the 3 screws from the back of the receiver. Once these are removed, the cover will come off.
  5. Volume Control Potentiometer Cleaning, Remove the retention pin on the faceplate: step 5, image 1 of 1
    • If the clip in the faceplate is missing, it has been previously serviced. It is not essential, but try to keep it intact as the bezel will always be loose without it.
    • This pin is installed by the factory. To remove this pin, push it out from the back until it is loose. Remove the pin when it is loose.
  6. Volume Control Potentiometer Cleaning, Remove the faceplate screws: step 6, image 1 of 3 Volume Control Potentiometer Cleaning, Remove the faceplate screws: step 6, image 2 of 3 Volume Control Potentiometer Cleaning, Remove the faceplate screws: step 6, image 3 of 3
    • After the clip from the faceplate is removed, remove the 2 screws that hold it to the chassis. Both screws are the same length.
  7. Volume Control Potentiometer Cleaning, Remove the knob from the receiver: step 7, image 1 of 2 Volume Control Potentiometer Cleaning, Remove the knob from the receiver: step 7, image 2 of 2
    • First time removal can be tricky. Take your time on a unserviced receiver.
    • Remove the control knob from the receiver. To do this, pull the knob off firmly. Too much pressure may result in a broken know and potentiometer.
  8. Volume Control Potentiometer Cleaning, Disconnect the front panel flex cables: step 8, image 1 of 3 Volume Control Potentiometer Cleaning, Disconnect the front panel flex cables: step 8, image 2 of 3 Volume Control Potentiometer Cleaning, Disconnect the front panel flex cables: step 8, image 3 of 3
    • Special attention to the front panel is required on iPod Direct models.
    • iPod Direct For iPod Direct models, disconnect the wire that plugs into the board as shown in the 1st picture. The board will need to be removed soon.
    • Disconnect the flatflex that connects the front panel display to the rest of the receiver.
  9. Volume Control Potentiometer Cleaning, Unclip the faceplate: step 9, image 1 of 2 Volume Control Potentiometer Cleaning, Unclip the faceplate: step 9, image 2 of 2
    • Once the unit is reassembled, these zipties must be replaced. Failure to do this will result in protection mode errors.
    • Cut the zipties that hold the front panel wires on the fan. This will provide better component access.
    • With the faceplate loose and all of the cables disconnected, unclip the faceplate one side at a time. Lay the faceplate flat on your workspace. Leave enough room to access the boards on the front panel.
  10. Volume Control Potentiometer Cleaning, Remove the iPod Direct board: step 10, image 1 of 3 Volume Control Potentiometer Cleaning, Remove the iPod Direct board: step 10, image 2 of 3 Volume Control Potentiometer Cleaning, Remove the iPod Direct board: step 10, image 3 of 3
    • This procedure will be different for non iPod Direct receivers.
    • iPod Direct: Remove all 4 marked screws. Remove the support bracket and PCB.
    • Non iPod Direct: Remove the Green and Red screws. No additional screws need to be removed.
  11. Volume Control Potentiometer Cleaning, Remove the faulty control board: step 11, image 1 of 2 Volume Control Potentiometer Cleaning, Remove the faulty control board: step 11, image 2 of 2
    • WARNING: This screw is unique and only fits here. Sort it separately.
    • Remove the 3 screws that hold the volume control board in the receiver's front faceplate.
  12. Volume Control Potentiometer Cleaning, Spray contact cleaner into the potentiometer: step 12, image 1 of 2 Volume Control Potentiometer Cleaning, Spray contact cleaner into the potentiometer: step 12, image 2 of 2
    • A little contact cleaner goes a long way. If you need to use more then 1-2 sprays, the board may be beyond repair.
    • With the control board loose from the front panel, spray contact cleaner into the potentiometer. Clean up any excess contact cleaner once you are done.
  13. Volume Control Potentiometer Cleaning, Wipe away any excess contact cleaner: step 13, image 1 of 1
    • This fix may not be permanent and the problem may come back. Replace the board or potentiometer if this happens. Let the switch dry for 30 minutes-1 hour before reassembly.
    • If you do not have zipties available, tuck the wires in the fan so that they cannot easily move. This isn't ideal long term, but can be used in a pinch.
    • Wipe off any excess contact cleaner on the PCB. Reinstall the board once the contact cleaner is dry.
Nick
89,092 Reputation
50 Guides authored
Master Techs Member of Master Techs
Community
321 Members
1,485 Guides authored
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 108
All Time: 9,804
