Voluas VL001 Screen/Motherboard Assembly Replacement
  1. Voluas VL001 Screen/Motherboard Assembly Replacement, Storage Tank: step 1, image 1 of 3 Voluas VL001 Screen/Motherboard Assembly Replacement, Storage Tank: step 1, image 2 of 3 Voluas VL001 Screen/Motherboard Assembly Replacement, Storage Tank: step 1, image 3 of 3
    • Remove the lid to the storage tank by using the latch and lifting off.
    • Grab the food storage tank on both sides. Depress the tabs that say "Push" on them and lift the tank off.
  2. Voluas VL001 Screen/Motherboard Assembly Replacement, Battery: step 2, image 1 of 3 Voluas VL001 Screen/Motherboard Assembly Replacement, Battery: step 2, image 2 of 3 Voluas VL001 Screen/Motherboard Assembly Replacement, Battery: step 2, image 3 of 3
    • Place your pet feeder upside down.
    • Squeeze the lock and remove the battery cover.
    • Remove the three 1.5V D alkaline batteries.
  3. Voluas VL001 Screen/Motherboard Assembly Replacement, Housing: step 3, image 1 of 3 Voluas VL001 Screen/Motherboard Assembly Replacement, Housing: step 3, image 2 of 3 Voluas VL001 Screen/Motherboard Assembly Replacement, Housing: step 3, image 3 of 3
    • Insert a metal spudger under the adhesive part of each rubber foot.
    • Pry the foot off.
  4. Voluas VL001 Screen/Motherboard Assembly Replacement: step 4, image 1 of 2 Voluas VL001 Screen/Motherboard Assembly Replacement: step 4, image 2 of 2
    • Remove four screws from the corners of the device using a Phillips #2 screwdriver.
    • These holes were previously covered by the rubber feet.
    • Using the magnetic tip of the screwdriver, carefully lift the screw out of the hole.
  5. Voluas VL001 Screen/Motherboard Assembly Replacement: step 5, image 1 of 1
    • Turn the device over so it is oriented right-side up.
    • Lift the top part of the feeder off, exposing the mechanisms that run the feeder.
  6. Voluas VL001 Screen/Motherboard Assembly Replacement, Screen/Motherboard Assembly: step 6, image 1 of 2 Voluas VL001 Screen/Motherboard Assembly Replacement, Screen/Motherboard Assembly: step 6, image 2 of 2
    • With the top part of the feeder sitting upside down, you can remove the chute.
    • Using a Phillips #2 screwdriver, remove the two 11.1 mm screws on either side of the chute.
  7. Voluas VL001 Screen/Motherboard Assembly Replacement: step 7, image 1 of 2 Voluas VL001 Screen/Motherboard Assembly Replacement: step 7, image 2 of 2
    • Grab the feeder chute on both sides and lift it off to remove it from the feeder.
  8. Voluas VL001 Screen/Motherboard Assembly Replacement: step 8, image 1 of 3 Voluas VL001 Screen/Motherboard Assembly Replacement: step 8, image 2 of 3 Voluas VL001 Screen/Motherboard Assembly Replacement: step 8, image 3 of 3
    • Using your finger, depress the tab that holds the assembly onto the device.
    • While pushing the tab down, push the screen out of the device.
  9. Voluas VL001 Screen/Motherboard Assembly Replacement: step 9, image 1 of 3 Voluas VL001 Screen/Motherboard Assembly Replacement: step 9, image 2 of 3 Voluas VL001 Screen/Motherboard Assembly Replacement: step 9, image 3 of 3
    • Using an opening tool, pry the dried silicone from around the connector.
    • Because you are working around the motherboard, try to limit how much you use its surface for leverage. It is a fragile part and can damage easily.
    • If needed, peel any remaining glue off with your fingers.
  10. Voluas VL001 Screen/Motherboard Assembly Replacement: step 10, image 1 of 3 Voluas VL001 Screen/Motherboard Assembly Replacement: step 10, image 2 of 3 Voluas VL001 Screen/Motherboard Assembly Replacement: step 10, image 3 of 3
    • Firmly grab the connector, just above the plastic end, and pull firmly to remove.
Jade Thomson
699 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 4
Past 30 Days: 7
All Time: 147
