Voluas VL001 Motor Assembly Gears Replacement
  1. Voluas VL001 Motor Assembly Gears Replacement, Storage Tank: step 1, image 1 of 3 Voluas VL001 Motor Assembly Gears Replacement, Storage Tank: step 1, image 2 of 3 Voluas VL001 Motor Assembly Gears Replacement, Storage Tank: step 1, image 3 of 3
    • Remove the lid to the storage tank by using the latch and lifting off.
    • Grab the food storage tank on both sides. Depress the tabs that say "Push" on them and lift the tank off.
  2. Voluas VL001 Motor Assembly Gears Replacement, Battery: step 2, image 1 of 3 Voluas VL001 Motor Assembly Gears Replacement, Battery: step 2, image 2 of 3 Voluas VL001 Motor Assembly Gears Replacement, Battery: step 2, image 3 of 3
    • Place your pet feeder upside down.
    • Squeeze the lock and remove the battery cover.
    • Remove the three 1.5V D alkaline batteries.
  3. Voluas VL001 Motor Assembly Gears Replacement, Housing: step 3, image 1 of 3 Voluas VL001 Motor Assembly Gears Replacement, Housing: step 3, image 2 of 3 Voluas VL001 Motor Assembly Gears Replacement, Housing: step 3, image 3 of 3
    • Insert a metal spudger under the adhesive part of each rubber foot.
    • Pry the foot off.
  4. Voluas VL001 Motor Assembly Gears Replacement: step 4, image 1 of 2 Voluas VL001 Motor Assembly Gears Replacement: step 4, image 2 of 2
    • Remove four screws from the corners of the device using a Phillips #2 screwdriver.
    • These holes were previously covered by the rubber feet.
    • Using the magnetic tip of the screwdriver, carefully lift the screw out of the hole.
  5. Voluas VL001 Motor Assembly Gears Replacement: step 5, image 1 of 1
    • Turn the device over so it is oriented right-side up.
    • Lift the top part of the feeder off, exposing the mechanisms that run the feeder.
  6. Voluas VL001 Motor Assembly Gears Replacement, Motor Assembly Gears: step 6, image 1 of 3 Voluas VL001 Motor Assembly Gears Replacement, Motor Assembly Gears: step 6, image 2 of 3 Voluas VL001 Motor Assembly Gears Replacement, Motor Assembly Gears: step 6, image 3 of 3
    • Using a Phillips #2 screwdriver, remove the six screws that hold the motor housing on to the device.
  7. Voluas VL001 Motor Assembly Gears Replacement: step 7, image 1 of 1
    • Lift the electric motor from its housing and move it aside.
  8. Voluas VL001 Motor Assembly Gears Replacement: step 8, image 1 of 2 Voluas VL001 Motor Assembly Gears Replacement: step 8, image 2 of 2
    • Use the tweezers to remove the first gear that is placed on top.
  9. Voluas VL001 Motor Assembly Gears Replacement: step 9, image 1 of 2 Voluas VL001 Motor Assembly Gears Replacement: step 9, image 2 of 2
    • Use the tweezers to gently remove the second gear.
  10. Voluas VL001 Motor Assembly Gears Replacement: step 10, image 1 of 2 Voluas VL001 Motor Assembly Gears Replacement: step 10, image 2 of 2
    • Use the tweezers to gently remove the third gear.
Jade Thomson
699 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 6
All Time: 122
