Volisun 4-inch Recessed LED Light Replacement
    1. Volisun 4-inch Recessed LED Light Replacement, volisun 4-inch Recessed LED Light: step 1, image 1 of 3 Volisun 4-inch Recessed LED Light Replacement, volisun 4-inch Recessed LED Light: step 1, image 2 of 3 Volisun 4-inch Recessed LED Light Replacement, volisun 4-inch Recessed LED Light: step 1, image 3 of 3
      • Before starting, make sure the light switch has been turned off and switch off the breaker for the fixture.
      Ask FixBot
    2. Volisun 4-inch Recessed LED Light Replacement: step 2, image 1 of 3 Volisun 4-inch Recessed LED Light Replacement: step 2, image 2 of 3 Volisun 4-inch Recessed LED Light Replacement: step 2, image 3 of 3
      • Find where the clips are for your LED light by pulling carefully.
      • Carefully pull down from one side where the clip is.
      • Press down the clip to not damage part of the ceiling.
      • Pull towards you so the other clips comes out.
      Ask FixBot
    3. Volisun 4-inch Recessed LED Light Replacement: step 3, image 1 of 3 Volisun 4-inch Recessed LED Light Replacement: step 3, image 2 of 3 Volisun 4-inch Recessed LED Light Replacement: step 3, image 3 of 3
      • Twist the cap counterclockwise.
      • Pull the cap up.
      • Disconnect the LED connector from the driver connection.
      Ask FixBot
    4. Volisun 4-inch Recessed LED Light Replacement: step 4, image 1 of 1
      • Replace the old LED light with a new one.
      Ask FixBot
    5. Volisun 4-inch Recessed LED Light Replacement: step 5, image 1 of 3 Volisun 4-inch Recessed LED Light Replacement: step 5, image 2 of 3 Volisun 4-inch Recessed LED Light Replacement: step 5, image 3 of 3
      • Attach the new LED light connector to the driver connection.
      • Put the cap back.
      • Twist in a clockwise direction.
      Ask FixBot
    6. Volisun 4-inch Recessed LED Light Replacement: step 6, image 1 of 3 Volisun 4-inch Recessed LED Light Replacement: step 6, image 2 of 3 Volisun 4-inch Recessed LED Light Replacement: step 6, image 3 of 3
      • Push both sides of the clips towards the middle.
      • Push up until the clips are inside the hole.
      • Push until it's flush with the ceiling.
      Ask FixBot
    7. Volisun 4-inch Recessed LED Light Replacement: step 7, image 1 of 3 Volisun 4-inch Recessed LED Light Replacement: step 7, image 2 of 3 Volisun 4-inch Recessed LED Light Replacement: step 7, image 3 of 3
      • Turn the breaker back on, flip the switch, and test the fixture.
      Ask FixBot
Finish Line
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 25
Past 30 Days: 157
All Time: 709
