Vodafone Smart V8 Display Replacement
    1. Vodafone Smart V8 Display Replacement, Display: step 1, image 1 of 3 Vodafone Smart V8 Display Replacement, Display: step 1, image 2 of 3 Vodafone Smart V8 Display Replacement, Display: step 1, image 3 of 3
      • To open the device you need do apply pressure at the bottom and up to get rid of the glued mini covers.
      Ask FixBot
    2. Vodafone Smart V8 Display Replacement: step 2, image 1 of 3 Vodafone Smart V8 Display Replacement: step 2, image 2 of 3 Vodafone Smart V8 Display Replacement: step 2, image 3 of 3
      • Put the back cover gently away - remove the finger sensor cable gently from the motherboard. Also put away gently battery and digitizer gently pull the cables from the glue as well the battery is well glued (you might demage it-very tight).
      Ask FixBot
    3. Vodafone Smart V8 Display Replacement: step 3, image 1 of 1
      • this was a complete teardown of the device - you can replace virtually anything.
      Ask FixBot
brejzek
97 Reputation
1 Guide authored
2 Guide Comments
Where can i buy the lte antenna sticker? I demaged mine while removing the plastick covers.
xlochman - Reply Share
Try Aliexpress I found there battery and display.
brejzek - Reply Share
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 58
All Time: 943
