Kindle Voyage Wifi Antenna Replacement
Views: 2.8K
View statistics:
Past 24 Hours:
3
Past 7 Days:
20
Past 30 Days:
99
All Time:
2,817
Comments: 18
17 comments on steps, 1 guide comment.
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Introduction
Go to step 1 ↓
If you are unable to connect to the internet with your Voyage there is likely a problem with your WiFi antenna. This guide is here to help you locate and remove it.
Tools
    1. Kindle Voyage Wifi Antenna Replacement, Back Panel: step 1, image 1 of 2 Kindle Voyage Wifi Antenna Replacement, Back Panel: step 1, image 2 of 2
      • Insert a plastic opening tool between the plastic panel shown on the device.
      • Use the tool to pry the plastic away from the device.
      • There will be adhesive holding this piece of plastic to the device. You may have to pull pretty hard to get it separated.
      Ask FixBot
    2. Kindle Voyage Wifi Antenna Replacement: step 2, image 1 of 1
      • Use an aluminum driver attached with a Phillips head size #00 to remove the four 3mm screws shown in the picture. For reassembly, note that the top two and bottom two screws are different sizes.
      Ask FixBot
    3. Kindle Voyage Wifi Antenna Replacement: step 3, image 1 of 3 Kindle Voyage Wifi Antenna Replacement: step 3, image 2 of 3 Kindle Voyage Wifi Antenna Replacement: step 3, image 3 of 3
      • Once the screws are removed, the back panel can slide off the device.
      Ask FixBot
    4. Kindle Voyage Wifi Antenna Replacement: step 4, image 1 of 2 Kindle Voyage Wifi Antenna Replacement: step 4, image 2 of 2
      • Remove the magnetic component with the magnetic head of the aluminum driver.
      Ask FixBot
    1. Kindle Voyage Wifi Antenna Replacement, Wifi Antenna: step 5, image 1 of 2 Kindle Voyage Wifi Antenna Replacement, Wifi Antenna: step 5, image 2 of 2
      • Use an aluminum driver with Phillips head #00 to remove the four 3 mm screws shown in the picture.
      • Use the same driver to remove the two 2.5 mm screws.
      Ask FixBot
    2. Kindle Voyage Wifi Antenna Replacement: step 6, image 1 of 3 Kindle Voyage Wifi Antenna Replacement: step 6, image 2 of 3 Kindle Voyage Wifi Antenna Replacement: step 6, image 3 of 3
      Tool used on this step:
      Buy
      • Using the tweezers, undo the attached clip.
      • Remove the three 3 mm screws holding down the rest of the antenna with an aluminum driver and the Phillips #00 head.
      • You should now be able to simply take the WiFi bar off of the device.
      Ask FixBot
Sean Yap
1,508 Reputation
6 Guides authored
Cal Poly, Team 19-12, Maness Winter 2015 Member of Cal Poly, Team 19-12, Maness Winter 2015
CPSU-MANESS-W15S19G12
5 Members
72 Guides authored
1 Guide Comment
Re Kindle Voyage Wifi Antenna Replacement guide: I cannot find the WiFi antenna bar on your website to purchase a replacement. Do you sell it?
carol cooper - Reply Share
Past 24 Hours: 3
Past 7 Days: 20
Past 30 Days: 99
All Time: 2,817
